Old April 4, 2009, 10:19 PM
gingerbee's Avatar
Default best overclocking software
ok its been awhile since i overclocked my video card and thought why not now what i am have trouble with is the stress test i was using ati tool but it does not work for vista 64 so i thought i would use furmark but that program is new to me ( so if i do the stress test in furmark the donut does not spin is this normal and second once i push my card to far should i see artifacts like you do in atitool in furmark any takers thanks )
card palit sonic 4870 watercooled ( if it helps )
Old April 5, 2009, 06:21 AM
gingerbee's Avatar
what so nobody overclockes there gpu anymore
Old April 5, 2009, 06:31 AM
I just use the crysis benchmark to test my cards, I let it do 10 loops and if I don't see any artifacts or it doesn't crash then it's fine.
____________________________________________
ASrock P45xe/q8200@2.8ghz/HD 4850+hd4830 crossfire/2xWD3200AAKS+0/4gb gskill 800/Samsung 245bw/Ocz Modxstream 600w
Old April 5, 2009, 07:15 AM
gingerbee's Avatar
thank i never thought of at all you are my savor i for the life of me could not get atitool work under 64 thank again
Old April 5, 2009, 07:25 AM
chrisk's Avatar
Folding Captain
Try folding with it. If its unstable then you will get "unstable machine" or "nans detected on the gpu" errors. Actually, many machines that are ATI tool and such 'error free' will crash under F@H.
3.0 Charlie has a sticky with lots of information on this too:
Overclocking tools of the trade
Fold for team #54196
Old April 5, 2009, 07:49 AM
gingerbee's Avatar
f@h is hard to setup no. i know nothing about folding at all sorry i have all those programs thank not new to overclocking just can't find artifact tester for vista 64
Old April 5, 2009, 08:11 AM
Delavan's Avatar
Whatever I use to OC my graphics cards make Punkbuster to detect "hardware monitoring" cr4p...and I get kicked until I disable the OCing software. I tried Rivatuner and Evga Precision (based on Riva anyway)...
So I OC to get more performance in games, but PB kicks me...
Do I play single player? NO...So my only option if I want to run an OCed GFX card in online multiplayer games is to BIOS flash (nibitor I think?) the card....
i5 2500K @ 4.5GHz / NH-U12P / P8P67 DELUXE / 8GB Corsair Vengeance Arctic White 1.35V 1600 / 2 x N560GTX Ti Twin FROZR II OC in SLI (8823 3Dmarks11 P-score)/ Corsair Performance Pro 128GB SSD
Old April 5, 2009, 08:25 AM
JD JD is offline
Never heard of this before...
As for stress testing, use OCCT: OCCT Website english Does the CPU and GPU
Old April 5, 2009, 08:50 AM
gingerbee's Avatar
never heard of that and i will try occt thanks for all the helps guys and or gals
Old April 5, 2009, 09:49 AM
bojangles's Avatar
I recommend what everyone else said. But could you please add a few periods and commas into your posts? I feel like my brain is running out of breath when I read them gingerbee.
In search of GPS software CMetaphor O/S's, Drivers & General Software 2 January 20, 2009 03:39 PM
Back up software?? Cowinacape O/S's, Drivers & General Software 7 December 31, 2008 05:00 PM
Any divice or software that can do this.... Gameplaywarrior HTPC Systems & Software 3 October 4, 2008 10:44 AM
Software WolfBane Networking 11 August 1, 2008 12:28 PM
Question regarding software 3.0charlie HardwareCanucks F@H Team 2 June 29, 2007 09:06 AM
