Old April 2, 2009, 08:56 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Yes maybe, but trust me a fan is all you need for any mem. Stuff like that looks cool but is really unnecessary.
Old April 2, 2009, 09:25 AM
Realityshift's Avatar
oooo thats a nice memory block my friend. how does that new water block hold the dims to the heat spreaders? it looks like theres screws holding it to the actual block which says to me that you could be fine with regular tim instead of adhesive? when its all put together it looks pretty damn solid.
The Builders Hammer
Old April 2, 2009, 09:31 AM
FB Dimms are no joke, they build up alot of heat and running them underwater isnt really a waste of money if you dont feel like having 80c parts burning up the ambient air inside your case. Makes more sense to run them at 40c. FB Dimm is alot more then super DDR2 im sure you release FB = Fully Buffered.
The Builders Hammer
Old April 2, 2009, 12:56 PM
My ram cost almost as much as my 2 X5460 Xeon CPU's (16GB) so If I choose to use more then a $10 fan to cool them, and they need cooling as Realityshift attested to, why must everyone always keep harping on me "a fan will do" "memory doesnt need more then a fan to keep it cool" I've heard it many times now and its just proof that you dont know what you're talking about.
Go throw a $10 fan on your $40 memory and leave me alone, the question wasnt should I go this way or that way (air/water) but about amount of TIM to purchase.
Have an A-1 day!
Old April 2, 2009, 02:06 PM
rjbarker's Avatar
Settle down....this Community belongs to "gentlemen"......
Firestrike Extreme: 21.452
MARK 11: 32.530
Old April 2, 2009, 06:56 PM
Nademon's Avatar
I didn't know you could get that much clamping force on the dims, but that insane waterblock thingy looks deadly! If it's providing good clamping force, I'd personally throw some TIM on there instead of tape/pads. I'm not too familiar with the FB memory and didn't know they ran that hot, but if that WB doohickey is the way you're going, then I'd be interested in seeing your results with some TIM! I'll keep my eyes peeled for how it works out for you.
REFS:
My Heat, Ebay, RedFlagDeals
Rig 1: CM HAF - Rampage Extreme - QX9650 - OCZ Gladiator Max - 4GB Mushkin DDR3 1600 - GTX280 - 2xBarracuda 500GB - 1xBarracuda 250GB - Pioneer DVD - Corsair 1000HX
Rig 2: Thermaltake Armor - P5K-E - E3110 - TRUE w/ 2 120's - 4GB Ballistix DDR2 1066 - 9800GX2 - 2xBarracuda 250GB - Pioneer DVD - Corsair 620HX
Rig3: Antec 900 - P5K-E/Wifi - E5200 - OCZ Vendetta 2 - 4GB OCZ DDR2 800 - 2x 8800GTS's - 1xWD Caviar 80GB - Pioneer DVD - OCZ 650W PSU
Old April 2, 2009, 07:15 PM
SugarJ's Avatar
To be honest, I'd take off the heatspreader on your FB-Dimms first, and test to see how level and true the chip surfaces are. If they are bang on, I'd use TIM. If not, I'd use thermal tape, as I think it would take up the gaps and transmit heat better than a too thick application of TIM.
This is just my opinion, based purely on speculation. And I'd love to see pics of that block installed.
Thermal Compound Removal Help no_pulse Guides & How-to's 36 May 7, 2010 10:45 PM
Pre-Applied Thermal Compound element291 CPU's and Motherboards 3 January 8, 2009 11:21 PM
Best thermal compound? Cadence Air Cooling 10 December 14, 2008 06:17 PM
Thermal Compound Review no_pulse CPU's and Motherboards 5 July 23, 2008 01:50 PM
change of thermal compound v0maru CPU's and Motherboards 0 March 18, 2008 08:13 AM
