Old March 28, 2009, 05:15 PM
Default 3D Vantage Results for my i7
http://valid.canardpc.com/cache/banner/538536.png
| Intel Core i7 920 @ 3.8GHZ | Noctua NH-U12P w/ 2 Synthe Kas 3000 | Gigabyte EX58 Extreme | Corsair Dominator 6GB | 2 WD SE16 500GB | BFG GeForce GTX 260 OC MaXcore 896MB | Corsair TX750 | LG SuperMulti DVDRW | CM HAF 932 | Samsung 2233BW | Windows Visa Ultimate x64 |
Old March 29, 2009, 09:07 AM
lowfat's Avatar
Disable PhysX next time. Those results are way off.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old March 29, 2009, 09:26 AM
gingerbee's Avatar
wow that's low what's up and with that i mean a 260 getting lower then 8800gt must be drivers
Old March 29, 2009, 10:33 AM
how u disable physixs?
Old March 29, 2009, 10:35 AM
lowfat's Avatar
In the Nvidia control panel.
Queen of Dreams WIP
Big Lian Li
Complete
Old March 29, 2009, 11:13 AM
i disabled it gave me a even worse score :S i dunno whats happening :P maybe i should get a better video card LOL
Old March 29, 2009, 11:22 AM
Futuremark came with a response to the accusations that Nvidia PhysX overwrites Vantage files. They decided that all the results using PhysX on a GPU should be removed from their Hall of Fame. The explanation is that they didn't mean the 3DMark Vantage to
work with GPUs supporting PhysX. So, they proceeded to updating the list without the named results. Also, they changed the way the results were organized in order to facilitate comparison, they say.
GPU PhysX Removed from Futuremark's Hall of Fame - The 3DMark Vantage was meant to work with PPU PhysX, not with GPU ones - Softpedia
I can explain what the story is, but let's jsut say using Phys-X does not give you accurate results. the lower scores you see without it are actually more accurate for your set-up, as your cpu score is falsely inflated. You cannot rely on the end score using Phys-X to judge system performance in Vantage.
Old March 29, 2009, 11:31 AM
i disabled phys-x and my score was even worse than the score i had there?
Old March 29, 2009, 11:49 AM
lowfat's Avatar
Yes. It is suppose to be. Otherwise the results are inaccurate.
Queen of Dreams WIP
Big Lian Li
Complete
Old March 29, 2009, 11:57 AM
Toronto122's Avatar
you should be well over 15000 with stock speeds on everything...something's up!
NZXT Rogue Cube Case
Intel i7 920 @ 3.8 w/Scythe Mugen 2
6 gb Patriot Viper 1600mhz low latency
Asus Rampage II GENE Motherboard
2 x Asus GTX 285 in SLI (710/1617/2700)
1 x 1tb WD Black
3 x WD 640AAKS in RAID 0
Enermax 85-1050 PSU
HP 30" 2560x1600, G19, G7, M-Audio Q40 Headset
3DMark 06 & Vantage scores Jonwall Overclocking, Tweaking and Benchmarking 206 March 25, 2015 10:19 PM
Innovation Cooling 7 Carat Diamond TIM Test results thread *NOW ACCEPTING RESULTS!!* Nademon Overclocking, Tweaking and Benchmarking 254 December 14, 2011 09:18 PM
3DMark Vantage Run - Core I7 280 SLI rjbarker Overclocking, Tweaking and Benchmarking 24 April 7, 2009 07:53 PM
gtx 295 sli/over 32k in 3d vantage hightest Video Cards 11 January 2, 2009 05:13 PM
How to get Far Cry 2 and Vantage *FREE* ! DarKStar Gaming 9 October 27, 2008 12:03 PM
