Old March 28, 2009, 04:57 PM
Default Need help getting my i7 920 stable with gigabyte ex58 extreme
I need help getting this stable. I had a Asus P6T Deluxe V2 which I fried and got this Gigabyte EX58 Extreme. I had my asus board stable at 3.8ghz with a 200 x 19 setting.
I'm having a hard time doing the same setting with the Extreme. Anybody got any ideas or advices?
http://valid.canardpc.com/cache/banner/538536.png
| Intel Core i7 920 @ 3.8GHZ | Noctua NH-U12P w/ 2 Synthe Kas 3000 | Gigabyte EX58 Extreme | Corsair Dominator 6GB | 2 WD SE16 500GB | BFG GeForce GTX 260 OC MaXcore 896MB | Corsair TX750 | LG SuperMulti DVDRW | CM HAF 932 | Samsung 2233BW | Windows Visa Ultimate x64 |
Old March 29, 2009, 06:53 AM
On my motherboard my cpu overvoltage, northbridge overvoltage and memory overvoltage leds are on. My cpu led has a slight green and moderate yellow, nb has slight green and memory has slight green. Will this be okay for 24/7 use?
Old March 29, 2009, 08:55 AM
MpG's Avatar
MpG MpG is offline
You're going to need to provide some concrete numbers before anyone can offer an educated opinion. And manufacturer ideas on acceptable voltage levels vary greatly. Some are excessively conservative, while others are nowhere near safe.
Old March 29, 2009, 10:34 AM
i have my vcore at 1.32v on the bios, everything else i have on auto.
Old March 29, 2009, 04:22 PM
crispex's Avatar
EVGA, anyone?
Old March 30, 2009, 04:32 AM
3.0charlie's Avatar
Read this guide: http://www.overclockers.com.au/files/Core%20i7%20920%20oc%204G%202008.12.12_(ENG).pdf Pretty good one for starters.
1.45 Vcore is not uncommon, my (once owned) 920 has seen folding temps of 70C+, and results will vary.
Hydro-Quebec is salivating...
Old March 30, 2009, 04:49 AM
yeah its weird i guess diff mobo diff stability i guess
i owned the asus p6t deluxe v2 b4 the extreme :P i had it stable at 3.8ghz with a 200 x 19 but harder with this one..
Gigabyte GA-EX58-UD5 X58 Motherboard Review MAC CPU's and Motherboards 15 May 11, 2009 11:28 AM
Gigabyte EX58-UD5/Exteme able to fit Forte? llama_egg CPU's and Motherboards 4 March 14, 2009 03:05 AM
Gigabyte MA790XT UD4P AM3 with 2x2gb 996601 NOT STABLE Drummer Troubleshooting 8 March 10, 2009 09:46 PM
Problems with ex58 extreme. sheepdogexpress Troubleshooting 5 December 7, 2008 06:04 PM
