Old March 23, 2009, 08:32 PM
gingerbee's Avatar
Default anyone who using hw monitor question
question under powers-processor it says 150 watts is this correct cause if so i might have a problem i don't think so
Old March 23, 2009, 08:42 PM
TDP for a 920 is 130 .. if you have it overclocked.. it'll be higher.
Old March 23, 2009, 10:09 PM
gingerbee's Avatar
so then this can be trusted ? as being right is there any where in everest that they give wattage to confirm
Old March 23, 2009, 10:13 PM
Right? Who knows..
Never trust software.. tho you could use RealTemp or CoreTemp cause I seem to recall one of them showing the wattage too.
Old March 24, 2009, 09:44 AM
gingerbee's Avatar
thanks i forgot core temp does watts 2
nVidia dual monitor question Squeetard Video Cards 2 January 14, 2009 12:16 PM
Another LCD TV as monitor question MpG Display Units 6 August 14, 2008 10:29 PM
Hd + Monitor Help derrXIII Display Units 3 July 28, 2008 03:33 AM
What should I ask for this monitor mailaw Display Units 4 May 1, 2008 11:43 AM
USB monitor anyone? Babrbarossa Reviews & Articles from the Web 0 June 18, 2007 01:19 PM
