Old June 11, 2007, 05:22 PM
Delavan's Avatar
Default I'm now confused Vcore real or not?
Hi,
I though I was grasping the concept of real Vcore, and searching for explanations, I ended up more confused that anything else. Please help me to clear this up...
Where this "real Vcore" term is coming from anyway...What is the "false" VCore? Does the Vdroop thing is part of this?
Read sig for OC info
E6420 stock Vcore (on the box) = Max 1.35 V
CPUZ reads 1.36V
Easytune (Gigabyte app.) = 1.38V
I manually set the Mobo in Bios to 1.4V...
Like I said, I searched first before posting this.
I want to determine if I'm using too much voltage, for long term "reliability" of the Proc..
i7 4770K @ 4.0GHz / Corsair H100i / MSI Z97A Gaming 6 / 16GB Kingston Hyper X 1.5V 1600 / MSI GTX1070 FE / Samsung 850 Evo 500gb / Corsair Performance Pro 128GB SSD / Intel 520 120GB SSD / WD Black 640 GB storage / XFX 850 watts Black Edition PSU
Old June 11, 2007, 05:49 PM
Delavan's Avatar
Now, Speedfan $.32 gives me a Core 0 reading of 1.36 volts...and Core1 of 1.9Volts...bad bad bad..
Old June 11, 2007, 06:18 PM
b1lk1's Avatar
1. Don't trust Speedfan. It is hardly ever right.
2. 1.4 in bios and 1.38V in Windows is pretty normal and that is what you call Vdroop.
Driving sim: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 290X 4GB/128GB SSD+750GB HDD
Daily: Intel DQ67SW/i7 2600/8GB DDR3/WD 150GB VR+2TB HDD/CU II R9 270 2GB/Xonar D1
Old June 11, 2007, 09:24 PM
Scratch's Avatar
You are looking for long term reliability although you have a 50% OC on your chip. There have been many posts on the problem with almost all apps differing in the Vcore report they generate.
Your easiest and best bet is to reduce your voltage until the pc refuses to boot, then raise it to a stable setting and run a burnin with the heavyweight program of your choice. If the computer doesn't crash after 12 hours of Orthos or Prime95 I'd say you have a good Vcore/FSB combination
I set my pc to 1.4 and it appears to run at 1.36 Vcore/3.2ghz stable. I don't know why you would consider 1.36 bad when the chip is rated to 1.55
Old June 12, 2007, 04:56 AM
Delavan's Avatar
Thanks for the replies folks.
1.4V (BIOS) IS what it takes for mine, below that I can't pass Orthos 8 hours.
Sorry, results of reading on electromigration... . If the chips stays stable for a good year and a half...I'm good to go I guess.
N.B. Speedfan freaks me out when I seen a diff. voltage reading for each core, one being out to lunch...but yes, speed fan is bad.
I would like to use Sisoft Sandra, but it tells me that the environment monitoring chips is not detected...
Confused 800mhz vs 1066mhz icodeit RAM 10 January 28, 2008 12:40 PM
Real Power Pro Krixxer Power Supplies 3 December 15, 2007 08:41 PM
E6750 throwing Vcore abnormality alert the_bandit87 Troubleshooting 1 August 22, 2007 10:08 PM
vcore fluctuations and oc magictorch Overclocking, Tweaking and Benchmarking 11 July 5, 2007 01:40 PM
Real tired of this crap..! Patriote Off Topic 10 May 10, 2007 01:31 PM
