Old March 16, 2009, 11:03 PM
Default Overclocking Using GigaByte Easy Tune 6
Having just recently completed a new build with a Gigabyte EP45-UD3P mobo and an E8400, I see it offers the Easy Tune 6. Has anyone experience with this product? Being that it seems to be a "quick fix" for overclocking, is it decent enough for general use? I have tried all of the "Quick Boost" settings and have been stable enough to run 3Dmark06 with the setting "3" ( 4.05GHz - FSB -1800Mz ). I've been running CPU-Z as well and seems to verify. I have not yet tried any real stress tests.
Overclocking is a new relam to me, as I've been stuck in Dell Hell, with the last computer not up to the task. So after lurking on this forum, and doing many hours of research, I built my own rig. Quite satisfying really. So now I want to see what it can do.
While I'm sure taking the more traditional route of hitting the BIOS and making the tweaks will pay of with better results, is there anyone using Easy Tune 6 with positive results?
My intial thoughts are that the Core Voltage may be a little high for the end CPU results.
Thank you in advance and may I say a very useful, and educational Canadian forum.
Cheers
The Build;
Gigabyte EP45-UD3P ATX LGA775 P45 DDR2 2PCI-E SATA2 RAID HD Sound 2GLAN 1394A CrossFireX Motherboard
Intel Core 2 Duo E8400 Dual Core Processor LGA775 3.0GHZ Wolfdale 1333FSB 6MB
XFX Radeon HD 4850 512MB XXX DDR3 PCI-E Dual DVI-I HDCP HDTV Out Video Card
G.SKILL F2-8500CL5D-4GBPK PC2-8500 4GB 2X2GB DDR2-1066 CL5-5-5-15 X 2 For 8GB Total
Western Digital WD1001FALS Caviar Black 1TB X 2
Corsair TX750W 750W ATX 12V 60A 24PIN ATX Power Supply
Antec Nine Hundred Mid Tower Gamer Case 900
LG GH22NS30 Black DVD+RW 22X8X16 DVD-RW 22X6X16 DL 16X/12X 2MB SATA
Vista Home Premium 64 Bit
Old March 17, 2009, 05:08 AM
3.0charlie's Avatar
I would love to help with ET6, except it doesn't play nice with my X58. Won't install for some odd reason. But the time I did play with it on my P45-DQ6, I must say it worked quite nicely.
You say the Vcore may be too high. What is it? Usually for 4.0, 1.4-1.45V is needed. What are the load temps (using Core Temp) and which HSF did you choose?
Welcome to the Forums.
The Four Horsemen. S8812 - 6174s - Ripjaws 16x2Gb - X25M - A5s - AX750W - 932ADV
Game on. X58A-OC - 930 - 560s - OCZ 3x 2Gb - Vertex 3 Max IOPS - TRUE Cu - AX750W - LC13 - U2412M.
Old March 17, 2009, 04:27 PM
Thank you for the response. I am running the stock intel HSF ( heat sink fan? ). The temps were in the high 50's. I have backed off on running @ 4ghz until I get a proper HSF. Now I'm cruising at 3.6ghz with 1.312v and core temps at 47.
Old March 17, 2009, 05:20 PM
3.0charlie's Avatar
Yup, HSF = Heat Sink Fan. Those temps, are they load temps?
Old March 18, 2009, 01:25 AM
Idle is 43, light load 47 - 50, medium to full load I hit 57 a few times. I haven't actually run any games for a long period of time, or done any real stress tests.
Old March 18, 2009, 05:17 AM
3.0charlie's Avatar
Try running OCCT for 2 hours. That's stable for me. But be very careful of those temps. Max 70c under load.
Old March 18, 2009, 11:54 AM
Thank you
Old April 13, 2009, 02:27 PM
somecanadianguy's Avatar
I've been trying to decide on using easytune6 on my new i7 build.
Motherboard is Gigabyte EX58-UD3R...
Everything at stock... cooling the CPU is a T.R.U.E
Temps right now are around 33 idle and 58 full load (according to RealTemp).
Are there any BIOS settings I should tweak before I use it... (Turbo, Hyper-Theading, ect...)? If it doesn't work out is it easy to get back to default settings? I have not OCd before and am learning... but would like to take advantage of this software if I can while I learn.
Tags
e8400 , easy tune 6 , ep45-ud3p , overclock
Radeon X1650 Pro tune up Mr. Gruntsworthy Video Cards 6 October 13, 2008 07:19 PM
GIGABYTE Open Overclocking Championship (GO OC 2008) MAC Press Releases & Tech News 17 September 24, 2008 10:02 AM
Gigabyte Launches Overclocking Contest Shadowmeph Press Releases & Tech News 4 December 21, 2007 12:39 PM
Problems Overclocking with Gigabyte GA-P35-DS3L DukeNukem Overclocking, Tweaking and Benchmarking 8 December 13, 2007 05:35 PM
