Old March 14, 2009, 08:33 PM
rjbarker's Avatar
Default Far Cry 2 Bench Runs I7 / E8400
For those considering an I7 as a gaming CPU.
E8400 @ 3.8 Ghz
4GB RAM @ 1 Ghz 4-4-4-15 2T Single GTX 280 XP 32 Bit DX9
Ranch Short 3 runs All Ultra No AA 1920 x 1200 - 49 FPS
E8400 @ 3.8 Ghz 4GB RAM @ 1 Ghz 4-4-4-15 2T 2 x GTX 280 SLI XP 32 Bit DX9
Ranch Short 3 runs All Ultra No AA 1920 x 1200 - 73 FPS
I7 920 @ 3.8 Ghz 6GB RAM @ 1.6 Ghz 8-8-8-24 1T 2 x GTX 280 SLI Vista 64 Bit DX10
Ranch Short 3 runs All Ultra No AA 1920 x 1200 - 101 FPS
Firestrike Extreme: 21.452
MARK 11: 32.530
Old March 15, 2009, 02:37 AM
Realityshift's Avatar
Hmm I didnt know the i7 made that much difference on frames, bet running 64bit and more ram helped too =) awesome benchmarks though RJ, very helpful.
The Builders Hammer
Old March 15, 2009, 06:00 AM
Is 2GB of Ram, 64 bit OS and DX10 not making a difference?
Old March 15, 2009, 07:05 AM
Babrbarossa's Avatar
Neat, thanks- I'd be curious to see what the single card score is for the i7 setup though. I'm wondering if any of the i7 advantage stems from better scaling in SLI.
Too bad you didn't have two 64 bit OSes- it migth even be interesting to run the i7 test under a 32 bit to level the memory address playing field (I know it's not practical for you though)
Old March 15, 2009, 08:25 AM
"Quote This..."
I have a single gtx 260 and my fc2 scores jumped from 50 to 70 fps over my q6600. People who say the i7 has no advantage for gaming just don't own one. I think a lot has to do with the huge bandwith of ddr3-1600mhz though. Almost triple my ddr2-1000mhz
Old March 15, 2009, 09:08 AM
hausner's Avatar
I just think that your q6600 didnt oc that well like your i7 and you was limited by cpu speed but yeah ddr3 memory bandwith is huge!
i7 6700K / Asus Z10L Pro Gaming/ Asus 1070 /Corsairs 16GB DDR4/ Samsung Pro SSDs/Enthoo Evolv mATX
Old March 15, 2009, 09:20 AM
MpG's Avatar
MpG MpG is offline
If you remember when Fixt ran through a whole whack of benches for FC2, there was a clear advantage for DX10, so that's got to account for something as well.
Old March 15, 2009, 09:28 AM
"Quote This..."
the q6600 was at 3890mhz, i7 at 3800mhz.
Old March 15, 2009, 09:45 AM
rjbarker's Avatar
Yeah I also did some Benches with FC2 @ 4.05 Ghz, but didn't have those numbers written down in my notes....of course its a "combination" of the I7 Chip, DDR3 Memory and perhaps DX10 (although many folks still claim games run better on DX9 vs DX 10).
Bottomline - this thing really does "rock the socks off" any Title I throw at it.....glad to see a Chip that can finally keep up to or pull away from the GPU's.
MARK 11: 32.530
Old March 15, 2009, 11:42 AM
"Quote This..."
yah mon. I was floored at my benchmarks with the i7, especially after hearing that these chips did not offer much for gamers.
Hogwash! Going SLI would not have jumped my scores higher than the i7 upgrade did.
18,098 to 23,945 in 3DMark 06!
Quick n Nasty FC2 n I7 Bench. rjbarker Overclocking, Tweaking and Benchmarking 0 January 24, 2009 08:05 PM
How hot does your GTX 260 runs? Efx Video Cards 12 December 5, 2008 03:18 PM
Ram runs at 800MHZ but... bushwickbill Overclocking, Tweaking and Benchmarking 3 October 5, 2007 04:00 PM
Safe test bench material? Mibs Overclocking, Tweaking and Benchmarking 12 July 31, 2007 05:02 PM
Vista 64bit vs. XP 32bit 4GB RAM bench comparo Eldonko O/S's, Drivers & General Software 13 May 14, 2007 01:09 PM
