Old March 11, 2009, 12:40 AM
Default q6600 overclock results; pls critique!
Hi Guys,
So, while I am not new to overclocking, this is my first time with a quad core. Just thought I would share my results so far...and consider any opinions/suggestions on what more/not to do !
As you will see, so far it is 3dmark06 stable....Will let you know how it goes overnight :)
Specs are as follows
P5Q Pro
q6600 G0 @ 3.6ghz w/ 1.48v
OCZ Vendetta Cooler @ 2400rpm
Patriot Viper 4gb @ 1066
8800GT OC2 @ 725/1800/1000
Old March 11, 2009, 01:14 AM
rjbarker's Avatar
Prime95 Blend - 4 - 6 hrs
Linpack / LinX 0.5.5 - 20 runs at Max Memory
Firestrike Extreme: 21.452
MARK 11: 32.530
Old March 11, 2009, 01:49 AM
Jackquelegs's Avatar
3Dmark 06 is not a good CPU stability test program.
It's much better to use Prime95 and run it for overnight
Use the blend tests to test both your CPU and FSB
Use the small FFT test to see the max temp on your CPU (pretty essential since you don't really want to go over 65 degrees for a Q6600)
So far the voltage looks alright, since my Q6600 will run 3.6ghz at around those voltages as well. However the temperature idling is 47 degrees, which is very high actually. You may want to stick to 3.2ghz with 400x8 at a much lower voltage.
What is your highest q6600 overclock? derrXIII CPU's and Motherboards 28 January 16, 2009 11:48 AM
Q6600 overclock to 3.0 GHz HermesĄ˘ RAM 10 November 17, 2008 09:06 PM
a rebuild. plz critique.............. rob123 New Builds 4 October 11, 2008 05:22 PM
please critique this build klaiboi New Builds 17 June 27, 2008 07:41 AM
Another... system critique! encorp CPU's and Motherboards 12 April 19, 2008 07:49 PM
