<~----> i7 voltage question - Page 2 - Hardware Canucks
Old March 9, 2009, 09:17 AM
rjbarker's Avatar
VTT and VDIMM need to be within 0.5 of one another, AFAIK that's the only one.
This other one you're mentioning is something I've not seen before.
+1.....haven't heard of the other he is speaking of either...
vcore @1.2 but comes out at 1.18 vdroop now my qpi/vtt is at 1.21 now i have heard that you should keep these within .03 of each other opinions please
.I was "amazed" at Gingers low vCore for his OC...then he posted above that his is with vDroop....Ginger ..in your Sig you have vCore 1.18v, really, if you are utilizing vDroop you should advertise what you have set in BIOS, not what the "load" value is....a little mis-leading is all.
I'm sitting right now at 3.66 Ghz BCLK 175 vDroop "without VDroop" and 1.225v.......still experimenting though.
Old March 9, 2009, 10:59 AM
gingerbee's Avatar
vcore @1.2 but comes out at 1.18 vdroop I am pretty that i said 1.2 oh i did that @3.8 with turbo on
Old March 9, 2009, 11:04 AM
gingerbee's Avatar
1.2 is what my bios is set to cpuz 1.184 idle and load dose not change so my load value is 1.184
920 OC Voltage questions SugarJ Overclocking, Tweaking and Benchmarking 3 March 5, 2009 08:45 AM
DRAM bus voltage Dogger1 Troubleshooting 13 February 18, 2009 08:12 AM
Over Voltage a35599 Overclocking, Tweaking and Benchmarking 6 February 26, 2008 09:21 PM
Overclocking question (Voltage) Wasza Overclocking, Tweaking and Benchmarking 2 January 22, 2008 10:28 AM
What is Stock Voltage? mattydies Video Cards 10 October 19, 2007 09:01 PM
