Innovation Cooling 7 Carat Diamond TIM Test results thread (goes live April 1, 2009) PLEASE READ THOROUGHLY BEFORE TESTING/POSTING YOUR IC7 RESULTS!!! :canadianwave::canadianwave::canadianwave: RESULTS THREAD IS NOW LIVE!!! PLEASE ONLY POST WITH RESULTS WHEN YOU HAVE FULL RESULTS, OTHERWISE YOUR POST MAY NOT BE SEEN BY ALL IF YOU RESERVE THE POST FOR LATER RESULTS WITH IC7. PEOPLE TEND TO GO TO THE NEWEST POST, SO IF YOU WANT IT TO BE SEEN BY ALL, POST YOUR RESULTS ONCE YOU HAVE THEM ALL. ALL OTHER DISCUSSION/SUPPORT POSTS, GO RIGHT AHEAD!! PLEASE BE SURE TO BENCHMARK YOUR CPU TEMPS WITH YOUR CURRENT TIM AND RECORD YOUR RESULTS BEFORE USING IC7 FOR TESTING. WE NEED BEFORE AND AFTER PLEASE! :thumb: ALSO, PLEASE MAKE SURE YOU DON'T CHANGE ANY VARIABLE OTHER THAN THE THERMAL COMPOUND USED FOR BEFORE/AFTER (I.E. SAME VOLTS/CLOCKS, COOLER, AND OTHER HARDWARE) APPLICATION METHOD For all those participating in the IC7 giveaway, please follow this link to the Innovation Cooling website: Innovation Cooling Proper application is the key to this product. The nature and consistency of this product is likely quite different from what most of you are used to in a Thermal Compound. Don't use traditional methods of applying the TIM like razor blades, lines, x's, etc. Through extensive testing, the best application method has been determined to be a pea sized amount directly in the center of the CPU. The TIM should be adequately spread via the downforce of the CPU cooler (a sufficient amount of downforce will provide best results; minimum 50psi of downforce should be the goal for optimum results. please see the Innovation Cooling website for more info). Also, for coolers/surfaces that have many peaks and valleys, it may be beneficial to wet the surface(s) with a small amount of IC7 to initially fill the voids in the mounting surfaces...then proceed with recommended application as usual. Please click on the link below for application methodology and shoot me a PM if you have any questions. Keep in mind, IC7 has been formulated with the specific goals of providing superb thermal conductivity with short set times, but also for long term stability and performance without pump/bakeout through extended thermal cycling or usage. This stuff is very stable over long periods of time. APPLICATION INSTRUCTIONS Please do feel free to navigate through the whole Innovation Cooling website as there is tonnes of information on there that might prove beneficial. HOW TO POST RESULTS THE FORMAT IS AS FOLLOWS (ALL TEMPS IN C): OPTIONAL INFO: PROCESSOR, VOLTS/CLOCKS, HEATSINK/COOLING USED, ETC. Pre-IC7 Compound: Abient Temp: Idle Temp: Load Temp: IC7 Ambient Temp: Idle Temp: Load Temp: If you have any problems or need support, please feel free to post here for now. The goal is to get all this info posted in the results thread which I will create shortly and ask Gav to sticky also. Remember, proper application and good even heatsink pressure (goal should be minimum of 50psi or more) are crucial for peak performance. Too much or too little compound will impact your results so please do visit the Innovation Cooling website for Application Instructions with images and explanations. There is a direct link in the second post in this thread. For those with direct touch heatpipe coolers, you might want to try wetting the contact surface of the cooler with a tiny amount of IC7 to fill any small voids before proceeding with the normal application method. :canadianwave: |
reserved |
reserved x2 |
Pre-IC7 Compound: Whatever came with my vendetta 2 Abient Temp: 18 Idle Temp: 29 Load Temp: 46 IC7 Ambient Temp: 18 Idle Temp: 29 Load Temp: 44 2 degrees lower under load, sometimes goes down to 43 or up to 45 but not for long. Idle temps remained the same as my previous tim |
Pre-IC7 Compound: Arctic Cooling MX-2 Ambient Temp: 20 Idle Temp: 37 Load Temp: 52 IC7 Ambient Temp: 21 Idle Temp: 32 :shok:(just mounted mind you) Load Temp: 46 Other Data Heatsink: OCZ Vendetta 2 + Bolt-thru Kit + Scythe S-Flex F http://www.hardwarecanucks.com/forum...img&imgid=5576http://www.hardwarecanucks.com/image...2aae39d300.bmp Amazing. I even though i messed up the mount :rofl: |
My set-up: CPU Block - EK Supreme Acetal North Bridge Block - Swiftech MCW30 Radiator - Swiftech MCR220QP Dual 120MM Tri Cools @ high speed setting, custom painted white Reservoir - Swiftech MicroRES V2 Pump - Danger Den DD-CP Pro Tubing - Primochill Primoflex 1/2" ID / 3/4" OD Tubing, Black w/ 3/4" UV Reactive Red Anti-Kinking Coils Coolant - Distilled Water, with Switech Hydrx Additive Loops order is: Pump<Rad<CPU<NB<Res<Pump http://i107.photobucket.com/albums/m...0/hardware.jpg Results with MX-2: Ambient - Approx 20C Idle - Core 0/1 - 32C Core 2/3 - 29C Load - Core 0/1 - 41C Core 2/3 - 38C Results with IC7: Ambient - Approx 21C Idle - Core 0/1 - 31 Core 2/3 -29 Load - Core0/1 - 39 Core2/3 -36 So, results here are basically no change with idle temps, and load temps gave me 2C cooler results. I also have a feeling that my bedroom has warmed up a tad bit since I tested the MX-2, so there may have been more of a difference that way. |
Pre-IC7 Compound: Artic Coolin MX2 Ambient Temp: 23Deg C Idle Temp: 41 - 38 Load Temp: 57 - 52 Pre-IC7 Compound: Silver Stone Abient Temp: 23 Idle Temp: 42 - 38 Load Temp: 57 - 53 IC7 Ambient Temp: 23 Idle Temp: 40 -38 Load Temp: 55 - 50 Other Data Heatsink: ThermalRight Ultra 120, with Single Noctua NF-P12 (pushing) System - Rig #1, Stock Clocks. Test Method - OCCT CPU Test, Default settings. |
And slntdth93, those are some great results!! that seems in line with what I got with a Vendetta2. Also, besides regular support/discussion posts, I think it would be best if everyone make a results post when they actually have results. Usually people just go to the newest posts so if you're reserving a post for later results, they may not get seen by everyone once the thread has tonnes more pages.:biggrin: |
Ill do some digging around in my old posts on some forums to see if i can get the temps i had under max oc with the old stuff and compare it, it wont be a direct comparison because conditions would have been different but it should give people a vague idea of how well this stuff performs under higher loads. |
I haven't gotten all of the results yet but I'll post what I have so far with my current TIM. I should have some IC7 results later tonight at which point I'll update this post. To stress the CPU I used Prime95's small FFT test. To stress the GPU, I ran FurMark. Pre-IC7 (CPU) Compound: Arctic Cooling MX-2 Ambient Temp: 22C Idle Temp: 33C Load Temp: 50C Pre-IC7 (GPU) Compound: Arctic Cooling MX-2 Ambient Temp: 22C Idle Temp: 39C Load Temp: 69C IC7 (CPU) Ambient Temp: 22C Idle Temp: 32C Load Temp: 48C IC7 (GPU) Ambient Temp: 24C Idle Temp: 38C Load Temp: 69C Processor: AMD Phenom II X4 920 @ 3.5GHz, 1.425v CPU Cooling: Sunbeam Core Contact Freezer with Yate Loon D12SL-12 Video Card: ATI Radeon HD 4850 512MB GDDR3 @ 650/1025 GPU Cooling: Akasa Vortexx Neo Tests were run in an Antec P182 case with side panel off. |
| All times are GMT -7. The time now is 01:30 AM. |
