  #81 (permalink)
Old March 30, 2009, 08:06 PM
ICD7's Avatar
MX-2
slntdth93/MX-2/-6
lpfan4ever/MX-2/-1
Asharp/MX-2/-2
Jshupka/MX-2/-4
phil3_66666/MX-2/-3
Inik/MX-2/-1.5
5ILVgeARX/MX-2/+1.1C
MacJunky/MX-2/ "0"
k3nnny/MX-2/-2
CasheKicker/mx-2/-2
SugarJ/MX-2/-1.5
Jackquelegs/MX-2/-2.5
Infiniti/MX-2/-21.5
Mike_E/MX-2/-6 (note post #79)
-6
-6
-6
-6
-6
AS5
cyberspyder/AS5/-7
kev.nam/AS5/-1
matsta31/AS5/-2
arekieh/AS5/-4
Misc. Compounds
Realityshift/Antec Formula 5/-2
Jonwall /stock paste/-2
CasheKicker/silverstone stock/-2.5
kyle_L/ ZM-STG1SUPER/-9
arekieh/OCZ Freeze/-4
sircuster/OCZ stock/-2
  #82 (permalink)
Old March 30, 2009, 08:11 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Amazing results to be sure.
  #83 (permalink)
Old March 30, 2009, 08:12 PM
stoanee's Avatar
Hmmmm...
So far my results have not changed from my MX-2.
Q9450 at 3.7ghz
18C ambient
Load using VMWare SMP folding, GPU folding and Prime 95 large FFT's
Xigmatek HDT-SD964 with Crossbow backplate, Scythe Kama flex 92mm "push" & Gelid Silent 9 92mm PWM "pull"
55-51-51-49
My first application was done by wetting the cooler and filling in the grooves on the cooler base with the help of a hairdryer to keep temps up and assist in the spreading. I put a pea sized glob on the cpu heatspreader and used the hairdryer to preheat the cooler in hope that the TIM would flow when the cooler was fastened down. Temps did not change at all so I removed the cooler to check coverage and it was very poor. Basically the TIM followed the heatpipes and did not spread sideways. Next I pre-wetted the cooler again and did the three line method that I have used to get satisfactory results with my HDT coolers, again no change. I will pull the cooler off to check the coverage again but I am now wondering if I have reached the physical cooling limit of this heatsink.
  #84 (permalink)
Old March 30, 2009, 08:40 PM
ICD7's Avatar
With the emphasis on application I do not feel from your description that there was any error there. When we analyzed the no result group to troubleshoot problems 80% were linked to light pressure loads or poor contact. Increasing pressure would be the most likely route. However in most cases I do not like to encourage people to kill themselves trying to get a result, this is a casual test you can let the result stand.
Alternatively I could send you some of the Contact/Pressure film to play around with to see if it indicates a direction for improvement if you feel so motivated.
  #85 (permalink)
Old March 30, 2009, 09:10 PM
CTA's Avatar
CTA CTA is offline
unbelievely -21.5 from "Infiniti/MX-2/-21.5 " i mean huge number will ruin average... (yeah i read his post)
if -21.5 is not including then average would be 3.47...
honestly according this result... i think your IC7 is best TIM...
NEW: customize case, hx100, i7 955, supreme hf, x58 sabertooth, 3gbx2 ram of ripjaws, xfx hd6950 CF. vertex 2 60gb, seagate and hitachi 1tb, dual mcp355 with ek rex v2, 2x koolance ar697, 2x mcr320, 6x zm-f3 fans.
OLD: cm 690, hx620, intel q9450, True Black, ga-ep45-ud3p, 2gbx2 ram of mushkin xp2 8500, xfx 285. wd caviar se16 640gb, 4x zm-f3 fans.
  #86 (permalink)
Old March 30, 2009, 09:18 PM
stoanee's Avatar
Consider me motivated.......oh wait...how do you view the contact results again?
  #87 (permalink)
Old March 30, 2009, 09:22 PM
SKYMTL's Avatar
Unfortunately, I believe that the averages should have both the highest and lowest result removed so they don't bugger up the overall numbers.
  #88 (permalink)
Old March 30, 2009, 09:35 PM
CTA's Avatar
CTA CTA is offline
well i believe mistaken (wrong way to apply tim, not tight, etc) is not acceptable...
  #89 (permalink)
Old March 30, 2009, 10:10 PM
Infiniti's Avatar
Well, yeah I agree that my results were a little strange, but I think the math was done wrong. I'm pretty sure that only the load was taken into the average, so from my calculations, (14+14+13+15)/4 = 14, not 21.
  #90 (permalink)
Old March 30, 2009, 10:47 PM
Jake_HT's Avatar
This stuff is NICE! I let it sit in steaming hot water for 5 mins prior to installation, and it went on good! Spread nicely.
Testing:
Pre-IC7
Compound:
Thermalright Chill Factor
Abient Temp:
Approx. 20c
Idle Temp:
39 33 36 36
Load Temp:
58 55 56 56
Pre-IC7
Compound:
OCZ Freeze
Abient Temp:
Approx. 20.5c
Idle Temp:
37 31 34 34
Load Temp:
56 52 54 54
IC7
Ambient Temp:
Approx. 20c
Idle Temp:
37 31 33 33
Load Temp:
55 50 51 51
Additional Info:
Intel Core i7 @ 3.8 GHz, Hyperthreading OFF, 1.245v core, Thermalright Ultra Extreme 120 with 2x120mm push/pull fans @ 1500RPM.
Temperatures recorded using RealTemp. Load at 100% for 20 minutes. Idle testing at 0% CPU usage for 10 minutes. All thermal paste used was allowed a 6 hour burn in period at 95% load. All thermal paste applied using pea sized application in center of CPU.
http://jakeht.deviantart.com/
Free innovation cooling 7 carat diamond tim giveaway!! Nademon Overclocking, Tweaking and Benchmarking 218 April 1, 2009 09:10 AM
X3 720BE > X4 :) The Results Thread :) arekieh CPU's and Motherboards 4 March 3, 2009 11:08 PM
[FS] IC Diamond 7 Carat TIM Apollo4g Buy/Sell & Trade 13 February 25, 2009 06:23 AM
First Results, First OC Soultribunal Overclocking, Tweaking and Benchmarking 2 January 31, 2009 08:57 AM
oc results so far Jim CPU's and Motherboards 7 July 25, 2007 01:52 PM
