  #221 (permalink)
Old May 16, 2009, 11:50 PM
CTA's Avatar
CTA CTA is offline
i can send you SV if you want...
but i already calculated it on my post...
Pre-IC7: thermalright chillfactor 2(? stock paste from black edition)
stock 2.66ghz
idle core0: 43
average: core0: 52.1, core1: 48.0, core2: 54.7, core3: 49.4
max core0: 56
IC7:
stock 2.66ghz
idle core0: 40.3
average: core0: 51.1, core1: 45.0, core2: 49.5, core3: 47.2
max core0: 52.7
today i tried to use OCCT on stock q92450 on stock ep45-u3dp and the room temperature is really hot... like 22... i got max 56 degree C on core0... o_O?
i think i will re-test it on right weather (maybe during raining day)
  #222 (permalink)
Old May 17, 2009, 11:39 AM
Unbelievable! This is on my Q6600 at stock, 1.248 volts under load
PRE-IC7
MX-2
Ambiant= 21 C
Idle= 38, 37,38,37
Load= 57,54,57,54
IC7
Ambiant=21 C
Idle= 36,35,35,36
Load=55,51,51,55
I never realized how much TIM can make a difference
  #223 (permalink)
Old May 17, 2009, 08:45 PM
Nademon's Avatar
awsome results klaiboi! What cooler are you using and what application method did you use?
REFS:
My Heat, Ebay, RedFlagDeals
Rig 1: CM HAF - Rampage Extreme - QX9650 - OCZ Gladiator Max - 4GB Mushkin DDR3 1600 - GTX280 - 2xBarracuda 500GB - 1xBarracuda 250GB - Pioneer DVD - Corsair 1000HX
Rig 2: Thermaltake Armor - P5K-E - E3110 - TRUE w/ 2 120's - 4GB Ballistix DDR2 1066 - 9800GX2 - 2xBarracuda 250GB - Pioneer DVD - Corsair 620HX
Rig3: Antec 900 - P5K-E/Wifi - E5200 - OCZ Vendetta 2 - 4GB OCZ DDR2 800 - 2x 8800GTS's - 1xWD Caviar 80GB - Pioneer DVD - OCZ 650W PSU
  #224 (permalink)
Old May 22, 2009, 09:39 PM
ICD7's Avatar
As agreed -3 C
  #225 (permalink)
Old May 22, 2009, 09:42 PM
ICD7's Avatar
"Crickets"
Any more results outstanding? or should I keep it open for a while longer?
  #226 (permalink)
Old May 23, 2009, 01:10 AM
Nademon's Avatar
I think there are a few more results pending so maybe keep it open a while longer. I'm going to go over my list shortly and see who's left...maybe send them a friendly poke. I have received messages from a few members who are still going to be posting.
REFS:
  #227 (permalink)
Old May 23, 2009, 06:16 AM
zlojack's Avatar
One of them would be me.
I need to just sit down for a couple of hours and get it done.
  #228 (permalink)
Old June 4, 2009, 08:56 PM
ICD7's Avatar
Default updating all forum results
I am updating all forum results to date for the website, 10 forums and you guys are included.
  #229 (permalink)
Old June 4, 2009, 09:26 PM
crispex's Avatar
Hmm... well, I never officially joined this little test, but I did see an immediate average drop of 10C across all cores after applying the diamond paste to the stock i7 920 sink. Possibly a little more.
I'm sorry, I'm probably breaking a rule or taking up space. I wish I'd recorded the actual statistics, but I forgot about this thread.
  #230 (permalink)
Old June 5, 2009, 09:19 AM
MarcusFoX's Avatar
Im not apart of the offical Test but Im going to post some specs temps anyways since I did buy it straight from HWC.
While doing these tests on my i7 HT was set to off @ 3.8ghz specs are in my signature. I have a 1/2 dtek system.
Pre-IC7
Compound: AC5
Abient Temp: 25c
Idle Temp:
cpu1: 41c
cpu2: 36c
cpu3: 34c
cpu4: 35c
Load Temp:
cpu1: 65c
cpu2: 62c
cpu3: 61c
cpu4: 61c
IC7
Ambient Temp: 25c
Idle Temp:
cpu1: 35c
cpu2: 30c
cpu3: 31c
cpu4: 31c
Load Temp:
cpu1: 56c
cpu2: 51c
cpu3: 52c
cpu4: 53c
http://i30.photobucket.com/albums/c3...i792038ghz.jpg
This stuff is amazing, I got almost a 10c drop on the first core underload.
good stuff if you guys have any spare tubes let me know id love to take them off ur hands.
A+ NET+ Linux+ LPIC-1 MCP MCTS MCSA MCITP
World of Tanks WGLNA
CSGO ESEA
Heatware: MarcusFoX
Free innovation cooling 7 carat diamond tim giveaway!! Nademon Overclocking, Tweaking and Benchmarking 218 April 1, 2009 08:10 AM
X3 720BE > X4 :) The Results Thread :) arekieh CPU's and Motherboards 4 March 3, 2009 11:08 PM
[FS] IC Diamond 7 Carat TIM Apollo4g Buy/Sell & Trade 13 February 25, 2009 06:23 AM
First Results, First OC Soultribunal Overclocking, Tweaking and Benchmarking 2 January 31, 2009 08:57 AM
oc results so far Jim CPU's and Motherboards 7 July 25, 2007 12:52 PM
