  #211 (permalink)
Old May 7, 2009, 07:40 PM
CTA's Avatar
CTA CTA is offline
sorry, i was very busying... i take some time to complete both TIMs...
pretty dirty for about 8 months...
i removed and suprised...
not center... i dont know why... maybe i moved thermalright cooler to west during install bolts?
Pre-IC7: thermalright chillfactor 2(? stock paste from black edition)
stock 2.66ghz
idle core0: 43
average: core0: 52.1, core1: 48.0, core2: 54.7, core3: 49.4
max core0: 56
3.2ghz
idle core0: 42
average: core0: 56.9, core1: 50.8, core2: 54.8, core3: 52.3
max core0: 59
first, i warmed up it in the hot bowl for 5 mins...
well i can't make it as large pea... so i do something like this...
its really hard to install during inside the case... i really should take out the mobo for easily installing fan and bolts... my hands and cpu cooler are too big for this small space ;[
warm up for about 12 hours because i found thermalright is little loosing... not enough pressure from bolts...
IC7:
stock 2.66ghz
idle core0: 40.3
average: core0: 51.1, core1: 45.0, core2: 49.5, core3: 47.2
max core0: 52.7
IC7:
3.2ghz
idle core0: 41.5
average: core0: 55.5, core1: 49.8, core2: 54.5, core3: 51.8
max core0: 57.8
soon i will try to test ga-ep48-u3dp and bolt mod too...
conclusion; its pretty good... about 3 degree difference... if i use a bolt mod for more pressure then it could make more different...
i also notice that real temp and occt temperature are different... if it were real temp then exactly 10 degree different.... for example... if 58 degree from occt then real temp would read as 48degree... so i am not sure anymore...
  #212 (permalink)
Old May 8, 2009, 10:07 PM
ICD7's Avatar
Default Reliability
Thanks for the attention to detail . I will update the running chart this weekend
I harp on reliability on all the forums but mostly I am ignored on the subject. For those that focus only on temps take a look what can happen in just a month.
The more liquid type pastes have more of a tendency to pump out or bake out. Though they wet well and give good performance out of the gate, if stressed you can run into this problem
  #213 (permalink)
Old May 8, 2009, 10:47 PM
Eagle Eye's Avatar
Sorry guys I have meant to get the results to you, but you know life and a 6 day work week. Just as soon I get things back to some form of normal I will get those results to you.
Regards,
EE
  #214 (permalink)
Old May 12, 2009, 10:39 AM
ICD7's Avatar
Another Review For those that have an interest
  #215 (permalink)
Old May 12, 2009, 11:15 AM
Lpfan4ever's Avatar
This stuff is so good. So good that you should send another tube to a guy who helped you gather info.
*coughcough*I'm all out*coughcough*
Bleh, I guess HWC is gonna get a buy from me, but these tubes go by so quickly. I got a Q9400, a GTX260 and a 9600GT out of the tube, and that's it
Originally Posted by encorp
Code:
<firebane> slightly used
  #216 (permalink)
Old May 12, 2009, 03:18 PM
CTA's Avatar
CTA CTA is offline
After the imposition of first rozsmarowywałem perfect paste all over the surface and then wyrównywałem "credit card".
not good idea to do that... it will create more air bubbles...
Diamond 7 - pasta here before the application was warmed up quite strongly, without it, unfortunately it could not be evenly spread.
not really... i can spread it without warm it up... but warm up it would be very helpful...
Orthos (priority 9, Small FFTs, set affinity, respectively)
not enough...
After 15 minutes the temperature was written down each of the cores
too short...
honestly, this article is not good to read...
  #217 (permalink)
Old May 14, 2009, 07:27 PM
ICD7's Avatar
This is a summary of the IC Diamond tests to date, any changes or corrections let me know.
  #218 (permalink)
Old May 16, 2009, 06:53 PM
joeperson's Avatar
Before (arctic silver 5)
Idle:Load
After (IC Diamond)
Idle:Load
No real change :| (difference in room temperature perhaps)
Q6600 3.0GHZ (9x333) stockV | ATI 5850 | OCZ Platinum 4GB PC2-6400 DDR2 5.4.4.15 1.9V | Silverstone Raven RV01 | Gigabyte EP45-DS3R
Corsair Professional HX750W | Windows 7 | Crossbow mounted Xigmatek HDT-S1283 | LG W2242TQ-BF 22" | Samsung 2253BW 22"
  #219 (permalink)
Old May 16, 2009, 08:54 PM
CTA's Avatar
CTA CTA is offline
yes, room temperature might be factor... or maybe not seated/pasted properly...
and i got 8 degree difference? i thought 3 degree... eh?
  #220 (permalink)
Old May 16, 2009, 10:24 PM
ICD7's Avatar
I have you down as 8/10 th's of a degree hard to see the period with the posted size. I averaged the load core temps then subtracted the difference off the 3.2ghz run. I'll recheck the math
Free innovation cooling 7 carat diamond tim giveaway!! Nademon Overclocking, Tweaking and Benchmarking 218 April 1, 2009 08:10 AM
X3 720BE > X4 :) The Results Thread :) arekieh CPU's and Motherboards 4 March 3, 2009 11:08 PM
[FS] IC Diamond 7 Carat TIM Apollo4g Buy/Sell & Trade 13 February 25, 2009 06:23 AM
First Results, First OC Soultribunal Overclocking, Tweaking and Benchmarking 2 January 31, 2009 08:57 AM
oc results so far Jim CPU's and Motherboards 7 July 25, 2007 12:52 PM
