  #201 (permalink)
Old April 28, 2009, 08:38 PM
Nademon's Avatar
Pretty good for stock cooler! Thanks for the results.
REFS:
My Heat, Ebay, RedFlagDeals
Rig 1: CM HAF - Rampage Extreme - QX9650 - OCZ Gladiator Max - 4GB Mushkin DDR3 1600 - GTX280 - 2xBarracuda 500GB - 1xBarracuda 250GB - Pioneer DVD - Corsair 1000HX
Rig 2: Thermaltake Armor - P5K-E - E3110 - TRUE w/ 2 120's - 4GB Ballistix DDR2 1066 - 9800GX2 - 2xBarracuda 250GB - Pioneer DVD - Corsair 620HX
Rig3: Antec 900 - P5K-E/Wifi - E5200 - OCZ Vendetta 2 - 4GB OCZ DDR2 800 - 2x 8800GTS's - 1xWD Caviar 80GB - Pioneer DVD - OCZ 650W PSU
  #202 (permalink)
Old April 30, 2009, 11:51 AM
Lpfan4ever's Avatar
I don't know if info is still wanted, but I took the plunge today and reapplied the TIM on my GTX260 Maxcore stock cooler. The highest I ever saw my card go was while playing Crysis Warhead, so I ran through the same level twice and here's my results (Forgot to get idle on stock):
Stock
Load - Max 81C, usually 77C
IC7
Idle - 41C
Load - Max 65C, usually 61C
Originally Posted by encorp
Code:
<firebane> slightly used
  #203 (permalink)
Old April 30, 2009, 12:49 PM
rjbarker's Avatar
Sorry for being so late with this and although late, the results have been hammpered by new MOBO. additional Fan on TRUE and ambient temps in the room being so different, here are my results.
Pre IC7 - Ambient Room Temp: 15 - 18c - X58 vanilla Board - TRUE Push config
Idle: 34-37c
Load P95: 68-73c
IC7 - Ambient Room Temp: 17-22c - X58 Classified Board - TRUE Push / Pull config
Idle: 34-39c
Load P95: 58-63c
Too many factors for a fair analysis, I also question whether or not I put "enough" or "large enough pea size" on the Chip. Temps seem ok considering the Room Temp, so I'll leave it be for now.
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
  #204 (permalink)
Old May 2, 2009, 07:08 AM
Nademon's Avatar
All temps stated are taken from the hotter of the 2 cores (the one further away from the fan and closer to the back of the case) from my 4870X2 at 777Mhz corespeed.
Hey all...here's a subjective example of my use of ICD. I have a Diamon 4870X2 which I just pulled from my main rig and installed in an HTPC case which is completely crammed and never meant to house a scorching huge card like the X2. So, with pretty pathetic airflow to the card, I manually set the fan to 75% (holy loud!) and started folding on both cores to see what the temps would be like. Well, at 75% fanspeed the temps would quickly climb to the 94C+ range and the card would keep shooting up to 100% fan speed and then back down to 75% as the temps dropped back down to about 94C. This would keep happening over and over again which was driving me nuts and I knew I couldn't have an HTPC that makes that much noise.
Shut everything down and took the X2 out. Replaced OEM TIM with ICD, put it back in the case and sealed it up. Manually set the fan speed to 45% (highest fan speed where I find the noise level to be acceptable for my living room) and started folding on both cores. Now, the temps peaked at 88C and hovers in the 86C range with the fan staying at a constant 45%.
So:
Diamond 4870X2 Stock cooler:
Pre-IC7: OEM TIM
Fan speed: 75-100% (auto function to keep temps in max safe range)
Loaded 2 Cores folding: 95C avg
IC7 TIM
Fan speed: 45% constant
Loaded 2 Cores folding: 86-88C
**IC7 Readings were taken 20 mins after application of TIM and 2 Cores folding full out so the 2 hour avg cure time isn't really represented here. My temps may come down a bit more through some cycling.
Just thought a practical application example might be interesting. My main benefit is now I can enjoy a relatively hushed HTPC where my temps are acceptable (while both cores are folding 100%) and I don't have to listen to the fan running intermittently from an unacceptably loud 75% (which still couldn't maintain a safe temp) to the ear-splitting 100%.
Great results from the members so far! I know there's still some more folks that will post up and I look forward to seeing them. Keep up the great work and I hope this has been an interesting, enjoyable and educational experience for all thus far.
REFS:
  #205 (permalink)
Old May 2, 2009, 07:42 AM
hightest's Avatar
yes it has been fun
id like 2 thank u nademom 4 the invite 2 the test, and ic7 4 the ic7 tim
i will use ic7 frum now on...i really like it when a company gets involved in a forum test like this.your getting a great product plus real dedication frum an xpert[ icd7]who puts in the time 2 help
it shows how confident they r in there product,and putting the time and effort into ansering ?'s on a forum,great support...and i learned a few things
eg= that is y i bought mushkin ram most of the time bcause of mushkin greg
thanks alot
Man all this computor stuff is 2 addicting.Even thou i dont need 2 i allways wanna upgrade.
  #206 (permalink)
Old May 3, 2009, 11:30 AM
ICD7's Avatar
Good stuff, If you have results post them. Right now you guys have pushed me over the 300 user result mark so thanks to all. And I will post an update chart when I get a chance
I have a small giveaway going with some laptop guys that adds a little different viewpoint to application potentials for those that have an interest.
Laptops
Andrew
  #207 (permalink)
Old May 3, 2009, 01:43 PM
mklym's Avatar
Andrew, I am a member of that forum. I will post my results there as well. I did not know you were running tests there, as the thread is in a part of the forum I very rarely visit.
Current Rigs
X301 ThinkPad 2776P8U
X301 ThinkPad 2774HDU
CF-18KHHZXBW Mk4 Panasonic w/GPS
CF-29HTLGRBM Mk3 Panasonic w/PMT vehicle dock, GPS
CF-52GFNBVAM Mk2 Panasonic w/voice capable aircard, GPS
CF-52CCABVBM Mk1 Panasonic X2
CF-74ECBADBM Mk2 Panasonic
CF-W5MWUYZJM Panasonic
Life's Journey is not to arrive safely at the grave in a well preserved body, but rather to skid in sideways totally worn-out shouting 'Woo Hoo! What a ride!
  #208 (permalink)
Old May 3, 2009, 01:52 PM
ICD7's Avatar
I would appreciate that, laptop comparisons are pretty rarefied and I would like to start accumulating more data on that. Thanks
  #209 (permalink)
Old May 3, 2009, 01:56 PM
mklym's Avatar
Already done. :)
Current Rigs
  #210 (permalink)
Old May 5, 2009, 04:10 PM
"Quote This..."
Finally got around to this. I just did my GPU. GTX 260 with swiftech waterblock. Used folding for the test.
Zalman ZM-STG1 idle 38 load 46
Diamond IC idle 38 load 43
Good stuff. I'll do my i7 920 tomorrow.
Black belt in CAPS LOCK.
Free innovation cooling 7 carat diamond tim giveaway!! Nademon Overclocking, Tweaking and Benchmarking 218 April 1, 2009 08:10 AM
X3 720BE > X4 :) The Results Thread :) arekieh CPU's and Motherboards 4 March 3, 2009 10:08 PM
[FS] IC Diamond 7 Carat TIM Apollo4g Buy/Sell & Trade 13 February 25, 2009 05:23 AM
First Results, First OC Soultribunal Overclocking, Tweaking and Benchmarking 2 January 31, 2009 07:57 AM
oc results so far Jim CPU's and Motherboards 7 July 25, 2007 12:52 PM
