  #161 (permalink)
Old April 19, 2009, 05:00 PM
Nademon's Avatar
You can just post the results here. Andrew has been collecting the date from this thread and updating the results chart.
REFS:
My Heat, Ebay, RedFlagDeals
Rig 1: CM HAF - Rampage Extreme - QX9650 - OCZ Gladiator Max - 4GB Mushkin DDR3 1600 - GTX280 - 2xBarracuda 500GB - 1xBarracuda 250GB - Pioneer DVD - Corsair 1000HX
Rig 2: Thermaltake Armor - P5K-E - E3110 - TRUE w/ 2 120's - 4GB Ballistix DDR2 1066 - 9800GX2 - 2xBarracuda 250GB - Pioneer DVD - Corsair 620HX
Rig3: Antec 900 - P5K-E/Wifi - E5200 - OCZ Vendetta 2 - 4GB OCZ DDR2 800 - 2x 8800GTS's - 1xWD Caviar 80GB - Pioneer DVD - OCZ 650W PSU
  #162 (permalink)
Old April 19, 2009, 05:13 PM
Realityshift's Avatar
I just found that by using the thin layer application method I dropped another 1c-2c off my max temps =) just a heads up but you have to make sure you warm the goo first or it doesnt work.
The Builders Hammer
  #163 (permalink)
Old April 19, 2009, 06:46 PM
MacJunky's Avatar
Even though IC makes a point of shooting down that method of application? Perhaps it has something to do with you using a HDT cooler while on IC's site they did not.
I must admit that I am tempted to buy some and play with it more. :P
  #164 (permalink)
Old April 19, 2009, 08:02 PM
Yeah I think it is the HDT that makes the difference, their methods just dont really work that well with the HDT and I find with the thin layer I get a much better imprint then with the xs or lines.
The Builders Hammer
  #165 (permalink)
Old April 19, 2009, 09:04 PM
rjbarker's Avatar
rj, your probubly allready have your rig put back 2gether,,but i used a about a 5mm dot in the middle of my cpu,my kids had a old plastic circle measering device with all differant sizeis of circels,so i got mine pretty close 2 what the website said about appying the compound
Thanks...and also thanks 3 of 7 for posting pics...I'll be home in 6 days so should be able to get going on the "Classified Re-build" then...looking forward to it ;)
Tri SLi "Procyon"
http://i30.photobucket.com/albums/c3...ant2/nice2.jpg
Evga 4.2 Ghz Club....
Tri SLi 580 MK11
http://i30.photobucket.com/albums/c3.../MK11Multi.jpg
Tri SLi 580 Vantage
http://i30.photobucket.com/albums/c3...ant2/60K-1.jpg
......Remember, keep your head up....and your stick on the ice
  #166 (permalink)
Old April 19, 2009, 10:16 PM
3 of 7's Avatar
Your welcome. I noticed that the cpu temps have dropped a degree or so in the last day or so ( I cycled the box on and off a few times to help seat the IC7) and it's now sitting right where it was with the AS5.
Nature always sides with the hidden flaw
  #167 (permalink)
Old April 19, 2009, 11:12 PM
rjbarker's Avatar
Sorry...how do you mean?
Tri SLi "Procyon"
Tri SLi 580 MK11
Tri SLi 580 Vantage
  #168 (permalink)
Old April 19, 2009, 11:22 PM
3 of 7's Avatar
I ran it up to operating temp (load) then turned it off till it was cool then ran it again.....
I did that 5 or 6 times.
  #169 (permalink)
Old April 20, 2009, 01:30 PM
Nademon's Avatar
Hey all..I know it's been a bit quiet around here lately, but just to touch base, ICD7 (Andrew) has just been away for a bit. He will be back shortly and I'm sure he'll be posting up the current data set. There's still more results to be submitted so we should be seeing some more posts upcoming. Thanks to all that have submitted so far, your data is much appreciated.
REFS:
  #170 (permalink)
Old April 20, 2009, 05:43 PM
rjbarker's Avatar
Thanks 3 of 6 ...gotcha!
Tri SLi "Procyon"
Tri SLi 580 MK11
Tri SLi 580 Vantage
Free innovation cooling 7 carat diamond tim giveaway!! Nademon Overclocking, Tweaking and Benchmarking 218 April 1, 2009 09:10 AM
X3 720BE > X4 :) The Results Thread :) arekieh CPU's and Motherboards 4 March 3, 2009 11:08 PM
[FS] IC Diamond 7 Carat TIM Apollo4g Buy/Sell & Trade 13 February 25, 2009 06:23 AM
First Results, First OC Soultribunal Overclocking, Tweaking and Benchmarking 2 January 31, 2009 08:57 AM
oc results so far Jim CPU's and Motherboards 7 July 25, 2007 01:52 PM
