  #141 (permalink)
Old April 12, 2009, 02:10 PM
sswilson's Avatar
The low idle temps are indicitive of the same "peak" phenominum (sp? :) ) as I mentioned WRT to load temp averages. Because the IC7 seems to transfer heat quicker (hence the +/- 2c swings when MX2 is staying stable) I suspect it caught the lowest point even if it was only for a fraction of the cycle.
  #142 (permalink)
Old April 12, 2009, 06:19 PM
sswilson's Avatar
Here's what I've come up with WRT my impression of the IC7 peaking at max temp vrs MX2 staying fairly consistent.....
The graph at the top is the IC7 and the one on the bottom is the MX2. Don't get caught up with the actual posted temps, as these are coretemp temps, and I'm not even sure if these MX2 readings are the actual ones from the run that ended up being recorded... I only know from the time frame that they are MX2.
If you look at the temps on the top graph (IC7) you'll see that the lower "load" temp is fairly consistant, while the max "load" temps are temporary spikes rather than the norm.
Looking at the temps in the lower graph (MX2) you'll see that the trend is just the opposite. On this graph the higher "load" temp (max) is fairly consistant, while the temporary spikes tend towards the lower temps.
Based on this, I'm pretty sure that the IC7 "average" temps over the whole 1 hour time frame would be at least 1c better (probably more) than the max/min peak readings would indicate.
Does that make sense folks or am I looking at this the wrong way?
  #143 (permalink)
Old April 12, 2009, 06:33 PM
mx2
ambient temp: 20c
idle, 28-31
load 59-65
ic7
ambient 20
idle 28-30
load 60-66
proc\ e8400 @ 4.05ghz 1.41v 9x450mhz,
hsf\ coolermaster eclipse,
mobo\ Asus P5Q Pro @ 1800MHz FSB ,
ram\ ocz xtc platinum 4gb 6-6-6-18,
videocard\ evga gtx280..superclocked?,
soundcard\ razer barracuda ac-1 ,
hdd\ seagate barracuda 7200.11 500gb,
os\ 7-64bit, ,
psu\ corsair hx620,
casefans\ 5x120mm, 1x200mm,
case\ antec 900,
mouse\ ocz equalizer,
keyboard\ microsoft comfort curve 2000,
mousepad\ toy story,
monitor\ samsung 2443bw,
fancontroller\ sunbeam four port rheobus,
  #144 (permalink)
Old April 12, 2009, 08:06 PM
MpG's Avatar
MpG MpG is offline
Very interesting, SS. Looks like I'll have to try some graphing of my own, just to see if I'm getting similar behaviour.
Been scratching my head a little over my own results so far, which are generating some anomalies of their own. Not the least of which is the fact that I'm seeing evidence of IC7 still curing (i.e. temps slightly improving) 12 hrs into a P95 burn. Beginning to wonder if I'm suffering from inadequate contact pressure, although my Fuzion V2 should be putting plenty on the IHS. Going to try spiking the springs for my fourth round of tests, see if that changes anything.
  #145 (permalink)
Old April 12, 2009, 08:25 PM
sswilson's Avatar
Please do. I'm very interested to see if anybody else is experiencing the same type of behaviour with this tim. I looked closely at it because I noticed that the load temps of the IC7 during benching seemed to indicate temps which were generally lower than the max temps I was getting. Seems to me somebody else mentioned temps which fluctuated by a fairly wide margin as well (edit: Found the post I was thinking about... Innovation Cooling 7 Carat Diamond TIM Test results thread *NOW ACCEPTING RESULTS!!* ).
It's also worth mentioning that with the AS5, the temperature was a steady 50*C. However with the IC7, the temperature kept fluctuating between 47-50*C, but mostly kept at about 48-49. The Idle temperatures on the other hand, dropped much more, which is odd
I suppose it could just be the mount I'm getting, but I'm theorizing that the IC7 medium might allow temp changes to transmit faster and that a WC loop wicks away heat fast enough for that to show up in the graphs.
I also noticed that the idle temps seemed to drop faster with the IC7 mount during the 30 minute cool down after load testing.
  #146 (permalink)
Old April 12, 2009, 10:12 PM
So, after having a whole bunch of issues with my new motherboard I have a few things sorted out (And no Raid 0 anymore...)
Stock temps:
Pre-IC7
Compound: MX2
Abient Temp:22C
Idle Temp: 41C
Load Temp:41 C
IC7
Ambient Temp:22C
Idle Temp:41C
Load Temp:41C
Stuck sensors, gotta love them :)
Overclocking (E5300 @ 3.6 - Quick and dirty)
Pre-IC7
Compound:MX-2
Abient Temp:22C
Idle Temp:41C
Load Temp:45C
IC7
Ambient Temp:22C
Idle Temp:41C
Load Temp:43C
The biggest and best difference I did find is that both cores are more inline with each other. No more having a 4-5C Difference in temps.
When my Boreas comes in later this week I will try it out as well. Maybe I can get some even better results (And also pulling my E2160 out of retirement)
  #147 (permalink)
Old April 13, 2009, 02:36 PM
Moneyless's Avatar
Here are some quick results with many different TIMs: (Full time consuming results to follow next weekend with all TIMs tested
OPTIONAL INFO:
E8400 @ 3600MHz 1.320v, badly-lapped TRUE w/ Scythe Kaze-Jyuni "Slip Stream" SY1225SL12M
Pre-IC7
Compound: Various
Abient Temp: 22 C
Idle Temp: See Graph
Load Temp: See Graph
IC7
Ambient Temp: 22 C
Load Temp:See Graph
"I hate broccoli
And think it totally sucks
Why is it not meat?"
-Deadpool
  #148 (permalink)
Old April 13, 2009, 03:40 PM
hightest's Avatar
355x9/1.125 v/tr-ultra 120 xtrem/syth 1200 rpm fan-push/ambeint 22c...1hr of occt
3.0.1
i used a 5mm drop of ic7 in the middle of my cpu/i measerd with the same tool used on the ic7 website/mabe a wisker more than 5mm
i had sum other compond no name brand , that i found but i think it was [10 days older than dirt] cause my temps shot up right away so i just did a shut down and removed the no name stuff
as5
idle=37c/28c
load 49c/41c
ic7
idle=37c/28c
load=46c/39c
i should have read the application process more carefully and heated up the tube in water bcause it was very very thick
Man all this computor stuff is 2 addicting.Even thou i dont need 2 i allways wanna upgrade.
Last edited by hightest; April 14, 2009 at 10:41 AM. Reason: 4got 2 tell how big of a drop of ic7 i used
  #149 (permalink)
Old April 13, 2009, 07:25 PM
ICD7's Avatar
updated post #134
  #150 (permalink)
Old April 13, 2009, 08:00 PM
Soultribunal's Avatar
Same thing Happened to me SS, I got a slight drop Initially , and then after the Hour long Prime Burn , I showed Better Temps right at the end.
The only one that gave me a World of issues was the AMD Mount, I got fluctuating Results until I got it seated properly (IC7 Wasn't Exclusive, It was a matter of getting the Right Spread , OCZ Freeze and Ultra Thermal have done the Same to me in the past).
All in all, it looks promising in the end.
ST
www.realhardwarereviews.com
Free innovation cooling 7 carat diamond tim giveaway!! Nademon Overclocking, Tweaking and Benchmarking 218 April 1, 2009 08:10 AM
X3 720BE > X4 :) The Results Thread :) arekieh CPU's and Motherboards 4 March 3, 2009 11:08 PM
[FS] IC Diamond 7 Carat TIM Apollo4g Buy/Sell & Trade 13 February 25, 2009 06:23 AM
First Results, First OC Soultribunal Overclocking, Tweaking and Benchmarking 2 January 31, 2009 08:57 AM
oc results so far Jim CPU's and Motherboards 7 July 25, 2007 12:52 PM
