Old March 4, 2009, 10:36 PM
SugarJ's Avatar
Default 920 OC Voltage questions
Alright gentlemen, having run my 920 up to a 185 bClk, I get some stability issues above that. This being my first i7, I'm wondering what your input is on max voltages for 24/7 use. And I mean 24/7, I fold. Keep in mind the chip is under water, so temps aren't an issue, at least yet.
What are your max comfortable voltages for vCore? CPU PLL? CPU Vtt? QPI PLL? IO voltages?
I may have hit the max bClk for this mobo, but I hope not.
Thanks for your input.
Old March 5, 2009, 04:17 AM
3.0charlie's Avatar
Vcore 1.45
PLL: 1.4?
vtt? Was always on Auto for me.
QPI 1.45, same as vcore
io Auto
Vram: 1.65V MAX.
Also make sure your CPU Uncore frequency is at least twice the speed of your ram. Drop the multi to 19, leave Turbo On. Double-check the QPI and don't overclock too high - stock is 4.8GT/s.
And check this out: EVGA X58 Overclocking Guide
Hydro-Quebec is salivating...
Old March 5, 2009, 04:24 AM
Jake_HT's Avatar
PLL Min voltage is 1.8v. Not sure about max, I run mine on auto...
Not sure about the EVGA board, but when I set my own multiplier (mine is 19) I don't get to choose whether or not turbo is on (assuming that it's off).
What clock are you going for Gord? Most people are using a 200BLCK, I'm 200x19 and it seems to be working very well.
http://jakeht.deviantart.com/
Old March 5, 2009, 09:45 AM
SugarJ's Avatar
Thanks guys. I was trying to hit a 200 BCLK, but wasn't sure how hard I could push this thing. More tweaking fun tonight. I'll try dropping the multi to 19x. I believe Turbo is always on with the EVGA's, which would hit my 4.0 Ghz.
Voltage setup when OC Wurmer Overclocking, Tweaking and Benchmarking 8 February 20, 2009 04:36 PM
DRAM bus voltage Dogger1 Troubleshooting 13 February 18, 2009 09:12 AM
Voltage advice. encorp Overclocking, Tweaking and Benchmarking 3 November 20, 2008 11:49 PM
Over Voltage a35599 Overclocking, Tweaking and Benchmarking 6 February 26, 2008 10:21 PM
What is Stock Voltage? mattydies Video Cards 10 October 19, 2007 09:01 PM
