Old February 24, 2009, 12:45 PM
matsta31's Avatar
the 60 C rule comes mainly from the fact that the CPU tended to become unstable once heavy over volting was applied at temperature over 60-65C.
When everything is at stock intel use different mechanism, like throttling or flat out shutting down the computer to protect the CPU. if it would become too hot, you would know it.
so everythign ia all right.
Now, OVERCLOCK ! :)
Sold hardware again.....
Currently using WHS hardware....
Old February 24, 2009, 05:02 PM
b1lk1's Avatar
The 60C rule is a farce. I have had completely stable overclocks well into the 80C's. Heat in iteself usually does not cause the instability, it is just an unstable overclock. While I don't recommend it, you can run your processor within 1C of the thermal design 24/7 and not cause any harm.
DAILY: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 270 2GB/128GB SSD+750GB HDD+2TB HDD
Real Temp or Core Temp ?? FrankyG Overclocking, Tweaking and Benchmarking 11 September 29, 2008 11:24 PM
Ati 4870 Temp Computergeek Video Cards 25 August 7, 2008 08:21 PM
Laptop temp killerklown Mobile Computing 7 March 6, 2008 01:32 AM
CPU Temp?? BALISTX CPU's and Motherboards 7 August 22, 2007 02:19 PM
CPU temp or Core temp? E6420 NOOB Delavan CPU's and Motherboards 18 May 28, 2007 05:07 AM
