Old February 22, 2009, 06:52 AM
WolfBane's Avatar
Default Old and New Settings
Ok last night oc before ever running Memtest86+
And this is this morning after running memtest86+
Old February 22, 2009, 07:04 AM
sswilson's Avatar
Cool!!!
That's a pretty hefty jump in memory frequency. :)
You'd probably be able to "tighten" those mem settings up in bios to match the 5-5-5-15 listed in the SPD for 500 MHZ.
Does your motherboard have a way to save "profiles" into the bios just in case you push the memory too far?
Old February 22, 2009, 07:06 AM
WolfBane's Avatar
Sure does steve but i don't understand what you mean tighten the mem settings in bios, i went in to my bios and set the memsettings there then ran memtest86+ twice and it said no errors! I am assuming thats a good thing ???
Old February 22, 2009, 07:07 AM
WolfBane's Avatar
So whats this do for me?
i mean with the 533 mem settings?
makes my programs faster ?
Old February 22, 2009, 07:14 AM
sswilson's Avatar
Most folks will let it run overnight to ensure stability.
It will make some calculations faster. How much affect it would have on your programs would depend on the program (some are more affected by memory than others). In real terms... most gamers would suggest that you wouldn't see much benefit to FPS if any at all.
Old February 22, 2009, 07:19 AM
WolfBane's Avatar
So what program do i run to test my cpu?
or is it at my stable max?
Old February 22, 2009, 07:21 AM
sswilson's Avatar
Prime 95, or OCCT are probably the two most popular CPU stress testers. The only way to tell if your CPU is at max stable is to stress it at current levels to ensure stability, and then to bump it up a bit and test it again.
Old February 22, 2009, 07:28 AM
WolfBane's Avatar
Ok lol man i am learning alot !!
so when i run this prime 95 does it take long ?
that memtest86+ took aver 1 hour to run the test twice:)
Old February 22, 2009, 07:56 AM
Well you really want to run prime for a minimum of 12 hours I do 24.
Cambridge,ON
MSI Z77 M Power/Bios17.12
3770K@4.5ghz
Mushkin #997007
Noctua NH-D14
Gigabyte GTX 660
Seasonic X-660
Corsair 540 Cube
Noctua case fans
Intel SSD
Win 10 Pro x64
3.0charlie's Avatar
Use OCCT 2 hours. But damn, that's some nice Ram running at 533! Loose at 5-7-7-20, but still!
Hydro-Quebec is salivating...
Memory settings in bios Jonwall CPU's and Motherboards 2 February 6, 2009 03:32 PM
Ram settings JupiterTrooper RAM 5 September 16, 2008 05:36 PM
Bad overclock settings? magictorch Overclocking, Tweaking and Benchmarking 0 December 2, 2007 01:59 PM
initial settings Jim CPU's and Motherboards 3 July 23, 2007 02:17 PM
Check your default HD settings sswilson Troubleshooting 5 July 7, 2007 05:37 PM
