Old February 21, 2009, 12:33 PM
Default whats wrong ??????
okay..so my gear is in my sig.
my friend help me oc easily to 3.6ghz with my old viper ram.
Now i've switched to OCZ HPC Reaper 1066mhz pc2-8500 4GB ram, then i tried to OC to 3.8ghz, unsuccessful. now i've done everything back up and running at stock, then i tried to oc to 3.6 again, but with new ram....unsuccessful...is OCZ ram really that garbage? or am i doing something wrong? this is how i do it :
1)BIOS
2)change OC to manual OC
3)change my ram speed to 1066mhz ( when i switched to new ram)
4)change rated fsb to 1600 (400 fsb)
5)multiplier @ x9 (deafult)
6) try to boot....
anyone willing to walk me through this? lol
CPU:Intel i5 6600k - Corsair H110
GPU:EVGA GTX980Ti FTW Edition
HDD:250GB Samsung Evo 850 SSD, 3TB WD Black
MOBO:Asus Z-170 Deluxe
RAM:G.Skill Ripjaws V F4 2800mhz 16GB
PSU:Silverstone 950W
CASE:Silvertstone TJ07
Keyboard:Logitech G15 V2
Mouse:Razer DeathAdder
Case Cooling:2x92mm exhaust,2x120mm exhaust, 2x120mm Ultra Kaze(3000RPM)intake.
Running:Win7 64-bit Ultimate
Old February 21, 2009, 12:52 PM
did you change the ram voltage? vcore?
You might have to maually set the memory timings as well. try setting the mem to 800mhz...does it boot?
Old February 21, 2009, 12:54 PM
well im running it on stock for now, why setting mem back to 800mhz ?
well, when my friend first oc'd he didnt need to do anything with voltages and i ran it @ 3.6ghz beautifully for the longest time til i got a new case.
but yeah, i played with the voltages for a long time, and either i suck at it or ..i dunno
Old February 21, 2009, 01:27 PM
sswilson's Avatar
Find out what the recommended voltage is for those sticks (manufacturer's website) and set it manually in bios. That's the most likely culprit.
You didn't mention a cmos reset when you changed those... that might do the trick (don't forget to write down your current settings for your CPU OC first). Many of the settings for memory are not user configurable, and it could be that your motherboard has set something in the background for your old memory that isn't compatable with the new memory.
edit: The reason it went to 800 at stock is because that is industry standard for DDR2. Your memory has been "binned" by OCZ to verify that they'll do 1066 speeds, but they still tell the bios to run them at DDR2 800 speeds until you manually change that setting.
Old February 21, 2009, 02:13 PM
Follow the previous posters......you can't just do those few steps you listed
ocz ram is fine ram
Cambridge,ON
MSI Z77 M Power/Bios17.12
3770K@4.5ghz
Mushkin #997007
Noctua NH-D14
Gigabyte GTX 660
Seasonic X-660
Corsair 540 Cube
Noctua case fans
Intel SSD
Win 10 Pro x64
Old February 22, 2009, 08:01 AM
yeah i know mobo stock will run ram at 800 mhz default. should i change it back to 800mhz then try to oc then change it to 1066mhz?
Old February 22, 2009, 08:52 AM
To me, the first thing I would be check is TRFC...probably wouldn't hurt to post on the OCZ forums...they should be able to help ya out there.
Some OCZ sticks, depending on when they were produced, need a SPD update to work properly without manually setting timings.
Old February 22, 2009, 05:46 PM
would a video of my settings/ocing (attempts) help?
Old February 22, 2009, 08:51 PM
Sure. A rundown of what's in bios would be great.
The revision of the sticks would be nice too.
Something wrong? paphman910 Off Topic 2 December 19, 2008 06:43 PM
Is CPU-Z wrong?!!? MognonMan Troubleshooting 2 June 28, 2008 07:56 AM
Did I do wrong? Jack Rabbit Off Topic 9 June 6, 2008 04:31 PM
Huh? What did I do wrong? Prof. Dr. Silver Suggestions & Feedback 6 April 22, 2008 09:51 PM
don't know what's wrong with me... Scratch Water Cooling 5 March 5, 2008 12:06 PM
