Old February 22, 2009, 10:22 PM
okay will post a video in a few days.
CPU:Intel i5 6600k - Corsair H110
GPU:EVGA GTX980Ti FTW Edition
HDD:250GB Samsung Evo 850 SSD, 3TB WD Black
MOBO:Asus Z-170 Deluxe
RAM:G.Skill Ripjaws V F4 2800mhz 16GB
PSU:Silverstone 950W
CASE:Silvertstone TJ07
Keyboard:Logitech G15 V2
Mouse:Razer DeathAdder
Case Cooling:2x92mm exhaust,2x120mm exhaust, 2x120mm Ultra Kaze(3000RPM)intake.
Running:Win7 64-bit Ultimate
Old February 23, 2009, 09:50 AM
punk_zappa's Avatar
When you installed the new sticks, did you clear the cmos? Clear it if you havent and try one stick at a time. I am not sure how the boards bios looks like but I would suggest to start off with 1:1 ratio.
Old February 24, 2009, 09:29 PM
YouTube - Cadence's Rig
here it is guys. couldnt find the revision for ram.
Old February 24, 2009, 10:35 PM
Problem is the the "auto" setting on cpu level-up, and alll the voltages on auto. All those things on auto for ovltage need to be set manually, especially the ram. Make sure the votlage is set to 2.2v, and yes, change that 5-7-7-20 to 5-5-5-15. TRFC can be set to 60, rather than 71. you may need to set chipset volts to 1.4 or so...I'm really not all that familiar with nVidia chipsets.
I'm sure someone else will have ideas as to what you set the other voltages to...
Old February 25, 2009, 07:41 AM
thanks cadaveca. I'll do that and let you know how it goes. anyone else for chipsets??? its a 780i chipset.
Old February 25, 2009, 09:27 AM
I'm currently using the same chipset. I'm using OCZ platinum DDR2 800 (not rev.2) With my 6400 8X at stock, I was able to overclock ram past 950mhz stable by bumping voltage close to your reapers. I am now stable @3.4 (8X425 1700fsb)with the following;
Unlinked
I have C1E disabled
mem optimal instead of expert
ram 5-5-5-15-23-2T, 15:16 ratio
SPP 1.45
MCP 1.52
I tried the 1:1 ratio, but couldn't get it stable
Try running your ram at 800 and see if it will boot.
Old February 26, 2009, 01:54 PM
changed trfc to 60, memory voltage @ 2.2v ...stable at 3.6..running p95 since last night . gotta go home and check on it later tonight..
Old February 26, 2009, 08:51 PM
stable at 3.6 on p95, ran for 22 hours lol
  #19 (permalink)
Old February 26, 2009, 09:12 PM
Ram is at 1066? or 800?
  #20 (permalink)
Old February 26, 2009, 09:42 PM
ram at 1066
Something wrong? paphman910 Off Topic 2 December 19, 2008 06:43 PM
Is CPU-Z wrong?!!? MognonMan Troubleshooting 2 June 28, 2008 07:56 AM
Did I do wrong? Jack Rabbit Off Topic 9 June 6, 2008 04:31 PM
Huh? What did I do wrong? Prof. Dr. Silver Suggestions & Feedback 6 April 22, 2008 09:51 PM
don't know what's wrong with me... Scratch Water Cooling 5 March 5, 2008 12:06 PM
