Old February 20, 2009, 04:05 PM
Wurmer's Avatar
Default Voltage setup when OC
I was wondering if letting the CPU voltage at auto is a problem when OCing you rig ? I am stressing my rig right now with the voltage at auto and it doesn't seem to pose a problem for the moment. It's not a huge over clock q9450 from 2.66 to 3.2.
Old February 20, 2009, 04:12 PM
thenewguy001's Avatar
If I remember correctly gigabyte's auto voltage settings will adjust the voltage according to your multi and FSB settings, so it might be safer to tweak voltages yourself in case auto is pushing it too high, either higher than necessary for stability (ie. wasted energy, more heat) or just beyond safety ranges. You might want to wait for someone else to chime in though as I'm not 100% positive.
i5 2500K @ 4.0 GHz
2 x 4GB G.Skill Ripjaws X
Patriot Pyro 240GB
Gigabyte HD 6970 OC
Gigabyte Z68X-UDH3-B3
Seasonic 760W
Coolermaster Hyper 212+
CM690 w/ 1-80mm, 6-120mm fans.
Old February 20, 2009, 04:13 PM
SugarJ's Avatar
Typically the auto settings over compensate and make the vCore higher than is necessary. Look at what voltage level it trys on auto, then manually set it. Then try one notch lower. Repeat.
If your vCore is too high, it can limit your OC by raising your temps unnecessarily.
"Quote This..."
Auto does nothing but set the stock voltage according to your cpu. So you are getting that overclock at stock voltage, pretty good. I go for max stable oc with decent temps so I always tweak the voltages.
If your temps are good, jump your vcore to 1.3-1.35 and go for 3.6ghz.
Old February 20, 2009, 04:18 PM
SugarJ's Avatar
Gotta disagree with you there. My auto vCore settings are way over CPU stock voltage. 1.35 vs 1.2 on my 920.
Typically, you can get about 80-85% of your chips OC capabilities on auto settings. Getting it the rest of the way is the fun part.
Old February 20, 2009, 04:21 PM
gingerbee's Avatar
imo yes auto likes to go way to high
Old February 20, 2009, 04:23 PM
Wurmer's Avatar
As far I as can see in CPU-Z my voltage is pretty much stable at 1.28 going at 1.26 once in a while. That's while stressing my rig with prime. Currently my temps are at 58-50-54-54.
Old February 20, 2009, 04:33 PM
SugarJ's Avatar
So try setting it at 1.26 in the BIOS. It may work there. Should drop your load temps slightly. Heck, it might do it at stock voltage, thats not unheard of for a 20% OC.
There's 2 ways to go about it. Achieve your desired OC, then drop voltages one notch at a time to see how low you can get and keep stable, or you can set your max comfortable vCore, and bump your FSB until temps get too high or chip not stable.
Old February 20, 2009, 04:36 PM
Intel says 1.3625v max for 45nm cpus, but this is also a consideration under stock cooling, etc, etc...all Intel specs assume certain environmental controls...
So, what I do, I set that 1.3625v in bios, and see how far it goes...
I set chipset volts to 1.4v, raise VTT to 1.25v(alot of boards undervolt @ 1.1v stock, auto may be much higher), and up she goes...
Some boards give INSANE voltages on auto...1.65v on some ASUS boards...so NEVER NEVER NEVER USE auto!!!
Don't trust CPU-Z. really. The program is good, really, but not accurate on every board....
DRAM bus voltage Dogger1 Troubleshooting 13 February 18, 2009 09:12 AM
Voltage advice. encorp Overclocking, Tweaking and Benchmarking 3 November 20, 2008 11:49 PM
X48 Max Safe NB Voltage for 24/7 use? soapman72 Overclocking, Tweaking and Benchmarking 6 July 13, 2008 10:21 AM
Over Voltage a35599 Overclocking, Tweaking and Benchmarking 6 February 26, 2008 10:21 PM
What is Stock Voltage? mattydies Video Cards 10 October 19, 2007 09:01 PM
