Old February 9, 2009, 09:40 AM
nige's Avatar
Default AMD 5000 BE on my Gigabyte GA-MA790FX
I finally tried overclocking my CPU. I have only changed one thing (made the multiplier to 14x instead of 13x) and i am running at 2.8ghz now. I don't notice any performance improvement, but I would like to push it a little bit further. I don't really want to touch the voltage, but i will try bumping the multiplier up to 15x to see if it will run @ 3 gHz. I don't have a fancy cooler. just a thermaltake silent K8 80mm cooler.
I didn't think it would be that easy to make the cpu run a little faster
Gigabyte GA-MA790FX-DS5 - AMD 1090T B.E. - Palit 4850 - 4x2GB Muskin 6400 - PC P&C Quad 750w - 500G WD Black - 500G + 250G WD Caviar - Xonar D2 - Win7 - Antec Sonata - Z680
Macbook Pro 13" - Intel CD2 2.53ghz - 4GB DDR3 - OSX 10.6.1
Old February 9, 2009, 10:12 AM
Eagle Eye's Avatar
Overclocking with that cpu couldn't be easier.
First what cpu cooler do you have?
Secondly set voltage in bios to 1.4v increase multiplier to 16 boot and viola 3.2GHz thats it. You likely won't see anything higher you could try, but I wasn't able to get anything stable above 3.2GHz.
For your memory just make sure the timinings are as tight as possible 4-4-4-12 at 2.0v 2.1v should work.
AMD 5000 X2 over Amd 940 JerryZ CPU's and Motherboards 4 January 19, 2009 07:58 PM
PCI-E link speed on Gigabyte GA-MA790FX-DQ6 with 2 HD3870 kybeer CPU's and Motherboards 0 December 13, 2008 04:25 AM
Little help please: 5000+ X2 vs BFG GTS 512mb PEIGuy Video Cards 14 April 24, 2008 10:18 AM
MA790FX-DS5 with phenom 9600 (I'm New here) derf007 CPU's and Motherboards 3 March 31, 2008 10:51 PM
Lg 226wtq 5000:1 ! Babrbarossa Display Units 6 October 13, 2007 10:54 AM
