Old February 10, 2009, 12:49 AM
Eagle Eye's Avatar
No, shouldn't be a problem. DDR2 1066 is good for an FSB of 533(run synchronously..1:1) Very highly unlikely that you could push that 9550 over 500FSB.
My board, experienced tweaking and faster memory will get you there, but all at the cost of memory bandwidth.
50-61oC if thats at full load you've already maxed out the stock cooling. An aftermarket cooler like the TRUE would do the same or better at 4.0GHz+ with increased voltage.
EE
I7 920 OC'ing results so far... rjbarker Overclocking, Tweaking and Benchmarking 18 February 16, 2009 09:05 AM
I7 920 OC'ing Queries rjbarker Overclocking, Tweaking and Benchmarking 4 January 24, 2009 05:00 PM
safe threshold for air OC'ing Mr. Cipher Overclocking, Tweaking and Benchmarking 9 February 13, 2008 03:06 PM
Need help OC'ing e6750 on an Asus P5K vertex112 Overclocking, Tweaking and Benchmarking 9 February 4, 2008 06:52 PM
SLI and OC'ing...???? frosty Video Cards 1 August 25, 2007 04:12 PM
