Old May 30, 2007, 03:25 PM
Default Ram overclocking with 680i and QX6700
New to the forums.
I have set up my machine to run at 3.33Ghz stable on air. What has been giving people better performance on their RAM? I have seen some running Linked & Synced, and others set the frequencies independantly.
My system specs:
QX6700 Quad Core
eVGA Nforce 680I SLI A1 Motherboard
2x eVGA e-Geforce 8800 GTX SC
2GB Corsair 9136C5DF
Corsair CMPSU-620HX PSU
2x Raptor 150GB HDs
Old May 30, 2007, 07:51 PM
Scratch's Avatar
heyas welcome...it depends on the memory I suppose.
I was running my E6400 on a 680i with the OCZ Titanium and was synced at 3.2/800mhz then ran linked at 3.6/900mhz however I found that the stated latency timings were not possible on this board even at 800mhz so I set it to auto and let the memory set its own latency opting for the higher speeds
Old May 31, 2007, 09:43 AM
Babrbarossa's Avatar
Welcome- Don't get too hung up on linked/synched. But you might want to try running superPi at linked/synched ddr2 832 with the lowest stable latencies, then try unlinked with looser timings like 5-5-5-12 and then run superpi again at the fastest stable frequency. Let us know what you find if you try it.
asusstriker extreme and quadcore qx6700 magictorch Overclocking, Tweaking and Benchmarking 13 July 27, 2007 09:23 AM
Kentsfield overclocking on nVidia reference 680i motherboard Misoprostol CPU's and Motherboards 34 March 26, 2007 10:52 PM
Vista + QX6700 = 50% OC sizerkozak CPU's and Motherboards 8 February 18, 2007 06:24 AM
Quad Cores are official: Core 2 Extreme QX6700 UNESCO CPU's and Motherboards 2 November 5, 2006 09:49 PM
