Old January 29, 2009, 07:16 PM
rjbarker's Avatar
Have you tried using the XMP profiles?
...?????...enlighten me....haven't heard of them.
EDIT: Ah...the Corsair Profiles.....haven't got CPUZ loaded...using E-Leet.
Firestrike Extreme: 21.452
MARK 11: 32.530
Old January 30, 2009, 01:11 AM
That ram seems to be underperforming. You should have it clocked in the 1800 range with that loose of timings.
Is your qpi unstable?
Old January 30, 2009, 12:17 PM
rjbarker's Avatar
No way....the RAM is spec'd at 8-8-8-24 1T @ 1600 Mhz..
Thier are definitely some issues I'm trying to sort out,,,but so far at a loss....With those settings above I was able to:
1. Run P95 FTT for 6 hrs
2. Run P95 Blended for 6 hrs
3. Run Linx 64 Bit 30x passes
Everything passes fine, but I'm getting strange Post problems, whereby I either have to hit Reset a number of times to get a proper Post or power off my PSU, then power up the Rig...really odd. This will occur with what appears to be a stable OC and even occurs with the "Dummy OC" enabled......I am now testing this back at Stock speeds to see if it continues.....
But no, I've been on the Evga Board steady with this for last 3-4 days and I don't know anyone running thier Dominators at 1800 Mhz stable.....
MARK 11: 32.530
Old January 30, 2009, 04:03 PM
Also add a bit more volts to your qpi pll. Approx 1.2 might help your overclocks. 1.35 I believe the highest recommended so you are still safe.
Have you tried to overclock the memory. Loosening the timings a bit might to 9-9-9-24 might get you to 1800.
My ram only rated to 1600 at 7-7-7-20, but I can get to 1950 if I loosen it up to 9-9-9-24 and that all at 1t.
Old January 30, 2009, 09:00 PM
rjbarker's Avatar
I've got "Boot Issues" I have to sort out prior to any further OC'ing attempts...seems I have to power off the PSU, prior to hitting the power button on the Case in order to guarantee a proper Boot up....friggin odd....won't be able to sort this out till I get back from work in a month...could be the Board...could be the PSU...who knows!?
MARK 11: 32.530
Old February 6, 2009, 11:16 AM
"Quote This..."
Stable at 4189. Cut the multiplier to 19x, set the base clock at 200, turbo on.
Old February 6, 2009, 11:30 AM
"Quote This..."
Holy crap. That's definitely a sweet spot. Was running at 20x180 before, scored 21019 3d marks. 200*19 upped my score 2000 points!
ORB - Compare
Edit: That's the 3rd highest gtx 260 score on ORB! With a stable daily gaming clock to boot.
Old February 14, 2009, 09:14 PM
gingerbee's Avatar
got to 4.0 but it's always almost 30c in my house the wife is cold all the time so with water i was hitting high temps like 80+ to high for me so i settled for an overclock with an undervolt at least thats what i think at stock it liked to run higher voltage
  #19 (permalink)
Old February 16, 2009, 09:05 AM
gingerbee's Avatar
from what i can tell the 3838A may need a lot more voltage to get to 4.0 but the good side is at 3.6 am at 1.184 and rock solid. I mean i have my ram at 1.45 for now waiting for summer temps.
i am under volting everthing from what i can tell and getting this speed. thank you intel
I7 920 OC'ing Queries rjbarker Overclocking, Tweaking and Benchmarking 4 January 24, 2009 05:00 PM
Help with OC'ing old school style Tazer-[X] Overclocking, Tweaking and Benchmarking 19 August 17, 2008 10:24 PM
Mini OC'ing my E8400 Cyanide55 Overclocking, Tweaking and Benchmarking 4 August 17, 2008 05:53 AM
safe threshold for air OC'ing Mr. Cipher Overclocking, Tweaking and Benchmarking 9 February 13, 2008 03:06 PM
SLI and OC'ing...???? frosty Video Cards 1 August 25, 2007 04:12 PM
