Old January 27, 2009, 09:42 AM
BrianHanna's Avatar
Default saddest thing i have ever read.
I bought the fastest CPU I could afford in order to avoid overclocking. I am not sure how overclocking affects the life of a component over time so I avoid it where possible.
I am forced to overclock to my Corsair RAM to get the 1066MHz speed (by using 2.2V) as this is how this RAM is designed.
Anyway, I ran Bioshock for around 45 minutes and my temps were: CPU 20C, MB, NB abd SB all at 43C and my 8800GTX at 60C. This is consistent with my findings when I ran Crysis for an hour or so and got the same temps except the CPU was at ~30C and the 8800GTX was at ~75C. The ambient temperature of my computer room is at 16.5C according to my desk clock thermometer. The cool rrom could explain why my CPU runs coller than expected by some.
in this thread on ncix
NCIX FORUMS - Running QX9650 + ASUS Maximus Formula SE
if only i could afford a cpu like that =/
Asus p6x58d-e / i7 930 @ 4ghz / G.skill 1600mhz 2x3gb 9-9-9-24 / Corsair TX750 / XFX HD 6850 1GB x2 @ 870/1070/ Coolermaster HAF 932 / Noctua nh12-up / Western Digital 500g Caviar black /Western Digital 1TB Caviar black 60Gb/ Seagate 7200.11 500g / OCZ Vertex 3 SSD / Samsung 2253BW / G5 / MX518 /
Old January 27, 2009, 09:44 AM
3.0charlie's Avatar
Had one like that - not worth the price. My i7 kills it, with less heat load.
Hydro-Quebec is salivating...
Old January 27, 2009, 09:47 AM
BrianHanna's Avatar
yea, but id assume someone would overclock an extreme version of a cpu
Old January 27, 2009, 09:52 AM
Phobia's Avatar
mine was at 4.2 ghz no problem. I wish I didn't get it however. I do not think its worth the price. Especially with the i7's out. However, when i bought it over a year ago, it was the best on the market
(whitty saying to be plagiarized at a later date)
Old January 27, 2009, 10:28 AM
"Quote This..."
Dual cores are all but done for gaming. Every new game out in the last few months has shown a marked iimprovement with 4 cores.
Old January 27, 2009, 10:43 AM
3.0charlie's Avatar
Don't get me wrong - that QX is one heck of a chip - mine ran at 4.4 daily. But the i7s are that much better: games, heatload, bandwidth.
Old January 27, 2009, 11:29 AM
Chilly's Avatar
Edit: Whoops, Chilly needs to learn to read.
Overclocking a CPU will not really shorten its lifespan by any significant amount. The 2 major things that will shorten a CPU's lifespan are heat and voltage. Frankly unless your pumping 1.7v and letting it run at 90c all the time, your CPU will last years past its usefulness.
Still, that being said, I can understand why one would avoid overclocking, its not really that hard, but sometimes stock speeds are plenty fast enough for 24/7 usage. Hell I run the 4870X2's bone stock, mainly because I saw little to no difference in performance when they were CCC(800MHz) maxed.
I agree though, that thread is pretty fail.
Old January 27, 2009, 12:04 PM
Menello's Avatar
You should have used quotation marks or something in the first post, I had no idea if that was you saying that or a quote from the thread until I actually read the thread itself. Call be crazy, but it wasn't exactly obvious.
I have my Q6600 overclocked, it just seems worth it for the increase of 600MHz without paying any extra money for a processor upgrade. Of course you do pay for cooling, but that's worth it. My video card is just running "stock" (as she came, anyway), because as Chilly said it doesn't seem to make a large difference. At least for me anyway... I'll have to give it another try sometime when my computer is ready to work for longer periods of time again.
The box:
Mobo: eVGA NF66 nForce 650i Ultra SPP
CPU: Intel Core 2 Quad Q6600 @ 3.03GHz
RAM: 1x2GB
OCZ DDR2-800 PC2-6400
+ 2x2GB Crucial DDR2-800 PC2-6400
= 6GB RAM (finally more than 2GB!)
GPU: XFX GeForce9800GTX+
HDDs: 500 Seagate, 640 GB WD Caviar Black
PSU: CoolerMaster 600W
The thing that bugs me the most. HermesĄ˘ Gaming 35 December 24, 2008 09:30 PM
Problem trying to get 'Read Only' file not Read only! bushwickbill Troubleshooting 5 August 10, 2008 12:41 AM
This thing PSU died, and I have pictures! mmmstew Power Supplies 13 May 22, 2008 12:12 PM
DirectCanada PIN thing tao5269 Off Topic 1 May 1, 2008 08:44 AM
The hall thing started from a cd... omgwtf Off Topic 6 November 15, 2007 04:48 PM
