Old January 26, 2009, 03:47 PM
element291's Avatar
Holy reposts batman!
| ASUS P8Z68-VPRO | Intel i5 2500K | 8Gb Patriot Viper Xtreme | 2x 60gb OCZ Solid 3 SSD | EVGA GTX260 Core216 |
Old January 26, 2009, 03:48 PM
Did you get the message?
Old January 26, 2009, 03:50 PM
element291's Avatar
I did. Question is... did the OP.
Old January 28, 2009, 07:41 PM
Eagle Eye's Avatar
Don't take it personally Frosty, it just never ends same question always comes up time after time.
EE
Old January 28, 2009, 11:46 PM
ya I got it, thanks...
i2600k sandy bridge @ 3.4ghz/ 2x 8800 GTX KO ACS3 PCI-E 630MHZ 768MB 2.0GHZ SLI'd / Raptor 74GB / Antec 1200 Hundred Gaming Case / G.Skill Ripjaws ddr3 1600 cl 8-8-8-24 - 8gigs / evga z68 SLI MOBO / Samsung DVD+RW / Corsair ax850 PSU / 24" Samsung CinkMaster
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Swiftech Apogee GT Cpu block
Feser One Red Fluid
Old January 31, 2009, 06:01 AM
i think the problem was before I started messing with the overclock again, I must have had it turned off because I had never had that issue. Had to reset the BIOS (pushing it too far) and must have missed the setting......... none the less, thanks again for the help..
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Feser One Red Fluid
Old January 31, 2009, 08:26 AM
Menello's Avatar
Well, I had mine turned "off" in the BIOS, yet it still managed to take my multiplyer down quite easily. But at least it puts it back anytime you use it.
I have it turned on now, actually.
The box:
Mobo: eVGA NF66 nForce 650i Ultra SPP
CPU: Intel Core 2 Quad Q6600 @ 3.03GHz
RAM: 1x2GB
OCZ DDR2-800 PC2-6400
+ 2x2GB Crucial DDR2-800 PC2-6400
= 6GB RAM (finally more than 2GB!)
GPU: XFX GeForce9800GTX+
HDDs: 500 Seagate, 640 GB WD Caviar Black
PSU: CoolerMaster 600W
textures changing in game, freezing - video card problem? tsincaat Troubleshooting 7 November 3, 2008 02:04 PM
The Times they are a changing. KnSKranky New Builds 0 September 3, 2008 05:29 AM
changing psu? djnocide Power Supplies 4 December 12, 2007 07:07 PM
Changing LED in a backlit keyboard BALISTX Peripherals 2 October 13, 2007 03:17 PM
Changing mobo, do I have to re-install Windows? francois methot CPU's and Motherboards 9 July 12, 2007 02:10 PM
