OC a 939 I'm looking for a little advice from an AMD owners out there. I've read the online guide posted in the sticky , so I have a rough idea what I'm doing. Just looking for input from anyone who has been there, advice is always appriciated! It is a Opteron 2.0gHz Socket 939 90nm. I also was briefly browsing the BIOS but couldn't find where the FSB and Multiplier values are located. The board is an Asus A8N32-SLI Deluxe :) Thanks in advance! ST |
let me take a look, i have OC ton's of those 939 system, can you give me a complete listing of your system,?? 2 or 4 sticks of ram, speed timing.. etc. what exact opteron it is, single dual core? 144, 146 or 170? what bios version and what psu |
Overclocking my 939 FX-60 is as simple as finding the multiplier and changing it on my old Asrock board. Usually it is pretty easy to find the multiplier. There is no FSB on a 939 however, it uses the HTT which is used for overclocking. |
CPU = AMD Opteron 170 2.0GHZ Dual Core 1MB Cache 90nm MB = ASUS A8N32-SLI Deluxe RAM = Mushkin EM PC3200 DDR400 CL3-3-3-8 2x1GB Sticks Video = ATI 9250 256meg PCI PSU = Power Up! 450w OEM CPU Cooler = Zalman CNPS9000 Case = ULTRA Luminaris BIOS is Rev. 1409 Flashed from Asus Update 3 days ago. Running Windows XP 32bit. Hope this helps, and Thank you both for taking the time. The only way I'm gonna learn is with some guidance and lots of trial and error. ST |
thnk for your info, i had type in a whole page for you but the server crashed when i hit the post button so i will have to do it again |
No worries, same thing has happened to me twice on here already lol! Regards, ST |
I also noticed thier Soul that you have an E8400 running at stock???? (your Sig) wtf....mines been at 4.05 Ghz for a year now with a vCore of 1.45...not a hitch...lets work on that puppy too !!!! |
Hahah hey RJ! I'd love to , but you should have noticed as well I have a DG35EC Board (Intel Vanilla Kind) so, no dice on the OC until I get either a new Asus Board, or New Gigabyte board. I also have a New in Box E8600 that is destined for whatever board I get. We will work on it though, in due time :) Regards, ST |
found my old book of notes i had bios 1103/ram at limit 200 means 1=1/[disable peglink it overclocks your v-card automaticly as u increase fsb]i ran mine at 250x10 1.250v cpu/limit 200 ram 2.60v ram 3-3-3-7 1t sb=nb link=16/16 k8=nb linkwidth=16/16 pci freq-100 k8=nb=4x stay at 1000 or less sb=nb mult=4 disable usb legacy if going over 250 fsb max async lat=auto dram responce time=normal read premable=auto idle cycle limite=256 dynamic counter=disable rwq bypass=16 bypass max=4 32 bit gran=4 burt that board should clock well the highest fsb i found in my notes was315x8=2520 cpu 1.275v/ram limite 166=252 2.60 v keep it at stock volts cpu should go pretty well i think i allso remember somthing else about a formula were u have 2 keep your ram and cpu volts inbtween a certan # or u can cause damage 2 the cpu ill look 4 that in my notes and post it if i can find it ill try 2 help u as u go along just ask ?s and i can look it up 2 c if i could help 2 change multiplyerset fid vid 2 manuel dont enable any overvolt settings [ eg cpu at 1.325=1.525 with overvolt enabled |
o.k i found that formula u take your ram voltage divide it by 2 then u subtract that answer from your cpu volts/ and im not a %100 sure but i think u dont want 2 go over a differance of 0.2 im sure the xperts here could confirm the xact # u dont want 2 go over |
