  #21 (permalink)
Old January 24, 2009, 06:09 PM
sswilson's Avatar
Try bumping your CPU &/or NB volts a notch... could be the extra drain on the PSU for 3D graphics is causing those voltages to drop below a stable level.
  #22 (permalink)
Old January 24, 2009, 07:34 PM
CPU is at 1.3 now, what should I try for northbridge voltage? The P5Q-E doesn't show what the current voltage is, just "auto". I also disabled load line calibration, that's the setting that reduces vdroop. I'll try enabling that, I just had it off for stability testing because it sometimes raises vcore under load then it could still be unstable when it's idle.
Q6600 G0 @ 3.0GHz - P5Q-E - EVGA GTX 260 Core 216 - Corsair TX750 - Coolermaster HAF 932 - Xigmatek HDT-S1283 - Mushkin Redline 2x2gb
  #23 (permalink)
Old January 25, 2009, 01:31 PM
Okay I just checked the voltages on my power supply by jumpering the 24-pin connector while everything was disconnected. 12v and 5v rails are fine but the 3.3v rail is only 2.75v. Worse yet, it drops to 2.69 when I measure the voltage while the computer is on. I think it's borked, should I RMA it?
EDIT: Ooops, sorry for double post.
  #24 (permalink)
Old January 25, 2009, 01:45 PM
sswilson's Avatar
20% sounds like it's out of spec to me, but SKYMTL would have a better idea of what is and isn't allowed for tolerances.
  #25 (permalink)
Old January 25, 2009, 02:00 PM
AFAIK even cheaper voltage regulators would probably still only be around ±5%. I've posted on the Corsair support forums, I'll see what they have to say on Monday.
EDIT: Funny, looking on the Corsair forums I found at least 5 other posts about shutdowns during gaming and one other post about a boot up problem that I am also experiencing. Maybe a bad batch got out or something.
  #26 (permalink)
Old January 26, 2009, 12:19 PM
You have lock the PCI bus speed at 100mhz. Did you do this? If not, and it's set to auto, it follows the FSB and you get an OC on the bus = unstable. That would explain why it is only present when you OC.
planning for new PSU Cadence Power Supplies 6 December 1, 2008 09:45 PM
Planning on a new build Jo5h New Builds 7 October 14, 2008 12:10 PM
Overclocking the Q6600 on an nForce 650i board Menello Overclocking, Tweaking and Benchmarking 3 August 20, 2008 11:29 PM
Planning on reisntalling Xp Rapid-X Storage 5 October 14, 2007 12:57 PM
Dfi P965-S Dark and Q6600 Overclocking keenan CPU's and Motherboards 2 September 23, 2007 03:16 PM
