Old January 23, 2009, 03:59 PM
Just finished: running at 3.0GHz@1.275v(Stock vcore!), loads at 45C during P95 smallfft. I'm really happy as is, I might push it a little further later after I guarantee stability after a longer prime test. Can I leave all of my northbridge voltages, RAM voltages, ect. on auto?
Q6600 G0 @ 3.0GHz - P5Q-E - EVGA GTX 260 Core 216 - Corsair TX750 - Coolermaster HAF 932 - Xigmatek HDT-S1283 - Mushkin Redline 2x2gb
Old January 23, 2009, 04:02 PM
sswilson's Avatar
IIRC, wasn't it the P5Q series that folks found extremely high auto NB voltage settings? (somebody help me out here... :) ).
I prefer setting my own NB & Memory voltages.
Old January 23, 2009, 04:49 PM
joeperson's Avatar
Gigabyte EP45-DS3R P45 Motherboard Review There's conflicting information about what's safe, they talk about it in the article. Overclocking to 3.9+ ghz on the Xeon E3110 from it's stock 3.0 helped push all the voltages up though. Not exactly the same situation if you stick to modest oc.
Q6600 3.0GHZ (9x333) stockV | ATI 5850 | OCZ Platinum 4GB PC2-6400 DDR2 5.4.4.15 1.9V | Silverstone Raven RV01 | Gigabyte EP45-DS3R
Corsair Professional HX750W | Windows 7 | Crossbow mounted Xigmatek HDT-S1283 | LG W2242TQ-BF 22" | Samsung 2253BW 22"
Old January 23, 2009, 05:30 PM
I had a prime stable system (40hrs), but I would occasionally experience strange BSODs. Ran IBT, failed, upped the voltage, IBT runs stable, no more strange BSODs.
I fail to see what's wrong with IBT. I wouldn't use it alone, but in conjunction with other tools, like anything else.
On what grounds are you saying IBT is bad?
Old January 23, 2009, 06:23 PM
Okay, now I've got a little problem. I was running 3DMark06 and the computer just shut down, and then it would intermittently just power off during boot and it would not POST. It would boot sometimes, so I reset everything back to stock. What could have caused this? Too much northbridge voltage, ram overvoltage? It seems like a power problem too me, so I'll try a different outlet soon. This seems strange, since I had run prime95 without problem for about an hour.
Old January 24, 2009, 06:29 PM
for it to be "prime stable" you should run it for more than 1hr. I typically do 24 hrs +
Most high performance ram like the redlines requires ~2.0v. Typically, motherboards have a stock voltage of 1.8v. You need to manually set the 2.0v volts. I would confirm the voltages for the redlines and double check the bios settings for it. as well, mobos seem to pick horible stock settings. Go post on NCIX and get mushkin_greg to recommend some settings (he is known for this :) ). I've seen unstable ram cause your symptoms, but there could be many other issues.
Old January 24, 2009, 06:51 PM
I've troubleshooted this all day and I'm 99% sure it's a problem with the GPU as I have run Prime95 for two hours, and memtest for an hour. I got no errors. I also tried an 8600 GT I had and the problem went away. My ram is set to 2.0v and I have posted on NCIX but mushkin_greg acutally no longer works for mushkin. Should I RMA the graphics card or is there anything else I can try? Also, the problem doesn't just happen on 3DMark. I was playing TF2 today and that caused it to shut off as well.
Old January 24, 2009, 06:53 PM
sswilson's Avatar
People have reported mixed results with it depending on what hardware they were running. Seems to work fine on some machines, others it seems to fail no matter that every other stress test passes with flying colours. (That's the point where I say don't worry about it.... :) ).
  #19 (permalink)
Old January 24, 2009, 06:54 PM
sswilson's Avatar
Does the same thing happen at stock CPU speeds?
  #20 (permalink)
Old January 24, 2009, 07:06 PM
Nope, it runs fine with stock speeds. Something's going on when I overclock that my graphics card doesn't like, it's a really strange problem. To be more specific, the card is an Asus EAH4850 TOP.
planning for new PSU Cadence Power Supplies 6 December 1, 2008 10:45 PM
Planning on a new build Jo5h New Builds 7 October 14, 2008 12:10 PM
Overclocking the Q6600 on an nForce 650i board Menello Overclocking, Tweaking and Benchmarking 3 August 20, 2008 11:29 PM
Planning on reisntalling Xp Rapid-X Storage 5 October 14, 2007 12:57 PM
Dfi P965-S Dark and Q6600 Overclocking keenan CPU's and Motherboards 2 September 23, 2007 03:16 PM
