  #81 (permalink)
Old November 19, 2007, 11:57 AM
Level up: 19% Level up: 19% Level up: 19%
Level: 15 - 524 points to level up
15167 with an 8800 GT at 720/1000
Futuremark - ORB - Project Comparison
  #82 (permalink)
Old November 20, 2007, 05:26 PM
Cptn Vortex's Avatar
Level up: 42% Level up: 42% Level up: 42%
Level: 21 - 701 points to level up
I did a quick run with my newly set up SLI system, and ran 16967 marks. Woot! I'll have to do some tweaking and post the results here, as it's a new board, gotta tweak the OC. Also, anyone know why ATItool reports my graphics card at the stock Overclocked speeds, but I have a non-overclocked GTX as the sister card. Are they running Unlinked??
The Vortex H20
Case....not sure what to call it
DFI X38 LT
Xeon X3210 @ 3.2GHZ 1.30V
PNY 9800GX2 (750/2200)
4GB Corsair Dominator 2x2gb kit DDR2 1066 5-5-5-15 2.0V
Ultra X3 1000W PSU
HT Omega Striker
2x500GB Hitachi RAID 0, 250 Seagate
Sharp 32" Aquos 1080p
Benq W500 1080i Pojector.
Watercooling:
Loop 1 - D-Tek Fuzion Quad Nozzle Bowed, MCR320+Zalman ZM-F3 Fans, MCP655, MCRES Micro.
Loop 2 - DB-1, DD 9800GX2 block, MCW30, MCR320, tLine res.
  #83 (permalink)
Old November 20, 2007, 05:33 PM
magictorch's Avatar
Level up: 9% Level up: 9% Level up: 9%
Level: 18 - 804 points to level up
Default Good score
Nice.
Did you OC those cards as well? Those P35 boards seem to be very solid.
I heard that two Intel teams were given the task of designing the P35 and X38.
For price to performance and future upgrades the P35 is a good option.
E6750/ Xeon 3350
DFI X38 LT
2 x 4870
74gb Raptor for OS, games
Thermalrock Dragon Case (sprayed black).
Loop 1: MCR 220 int. ; Apogee GT block.
Loop 2: MCR 320; Swiftech Res.;
2x EK FC blocks.
Pumps: 2x MCP655.
  #84 (permalink)
Old November 20, 2007, 05:55 PM
Well, it was a p35... Had to go 680i to run SLI. No, I didn't overclock the cards. Essentially, the one card is factory overclocked, and the second card is stock. But according to ATItool, it still shows the card(s) running at the Overclocked speeds, even when SLI is enabled. Maybe it's a bug?
The Vortex H20
DFI X38 LT
Ultra X3 1000W PSU
HT Omega Striker
Watercooling:
  #85 (permalink)
Old November 20, 2007, 11:04 PM
Jokester's Avatar
11412 time to move to Intel I think.
  #86 (permalink)
Old December 12, 2007, 10:36 PM
Babrbarossa's Avatar
Super Moderator
Finally broke 14K-(14355) I think the new memory helped (In Sig, running at 1100 5-5-5-12)
Building: ASUS P6T X58// i7 920 // SLI evga 260GTX 216SC// 3X2GB Patriot Viper DDR3-1600// Antec TP Quattro 850w // CM Stacker 830
Water Cooling: Apogee GTZ// 2X evga HC16 GPU block// HW Labs Black Ice GTX Xtreme 360 // Swiftech MCR220 // Swiftech mcp655 pump
HTPC: Asus Commando // e6400 @ 3.4 // Crucial Ballistix PC2 8000 // evga 260GTX 216SC// LG super opti-blue HD optical drive// DVB clone PCI satellite receiver//OCZ GXStream 700w // ACFP7 CPU cooler // Antec p180
  #87 (permalink)
Old December 13, 2007, 08:57 AM
FritzGuy's Avatar
Level up: 6% Level up: 6% Level up: 6%
Level: 7 - 130 points to level up
I guess I'm not so bad off with my Core Duo 2.0 Gig compaired so some of the newer stups you guys have
and this is done on a Asus P5W-DH Deluxe ) awful Bios for O/C and an old chip set 975x...BTW I have overcloked my 8800 GT ( vanilla ) to the ( KO ) settings also...all temps are well withing the limits with just fans
  #88 (permalink)
Old December 14, 2007, 08:22 PM
3.0charlie's Avatar
Still can't see your screenshot, since it is not a link.
Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182
HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B
  #89 (permalink)
Old December 14, 2007, 10:33 PM
Prof. Dr. Silver's Avatar
Hardware Canucks Reviewer
I just got my E6850...and so far I only got it up to 3.7GHz....so prey while you wait for new bench numbers! w00000t!
  #90 (permalink)
Old December 15, 2007, 12:29 AM
Patriote's Avatar
Level up: 10% Level up: 10% Level up: 10%
Level: 17 - 721 points to level up
and 24\7 Clocks :
Not bad :) Can run Crysis @ Very High DX10 1680 x 1050 with Decent FPS.
• - EVGA 680I A1
• - QX6800ES G0 @ 3.95Ghz
• - SLI BFG 8800GTX @ 626Mhz \ 2000Mhz
• - 4GB G.SKILL F2-6400PHU2-HZ @ 1000Mhz
• - Ultra X3 1000 Watt
• - X-FI XtremeMusic \ Klipsch Promedia 2.1 THX
• - WD RaptorX 150GB \ WD500GB \ WD Caviar 250GB
• - MountainMod U2-UFO Black Powder Coat
• - Dell UltraSharp 24''
Loop #1 : D-Tek FuZion - 2x MCW30 - Cyclone Res - MCP355 w/ Petra's Top - PA120.3 - Tygon
Loop #2 : 2x Ek-FC 8800GTX - Ek 150 Rev.2 - MCP355 w/ Petra's Top - PA120.2 - Tygon
Hotfix for 3DMark06/05/03 and PCMark05 Eldonko Drivers 0 February 29, 2008 02:12 PM
Performance Review nVidia in 3DMark06 Prof. Dr. Silver Video Cards 2 November 18, 2007 12:11 PM
AquaMark 3 Benchmark Prof. Dr. Silver Overclocking, Tweaking and Benchmarking 2 November 15, 2007 09:26 PM
New 3Dmark06 World Record by Shimano SKYMTL Reviews & Articles from the Web 5 July 25, 2007 05:40 AM
