Register Sweepstakes VB Image Host Members List LAN Calendar Search Today's Posts Mark Forums Read
LinkBack Thread Tools Search this Thread Display Modes
  #51 (permalink)
Old June 23, 2007, 08:22 PM
Level up: 55% Level up: 55% Level up: 55%
Level: 10 - 128 points to level up
I just ran 3dmark06 and got 10660 with stock settings on this new rig of mine. I'll work on pushing my numbers up over the next while and see where I can get this machine up to.
CoolerMaster CM Stacker 832
Enermax Galaxy Dxx 850W
Intel e6700 lapped/D-tek Fuzion
EVGA 680i A1/Swiftech MCW30 NB cooler
4Gb OCZ Flex XLC DDR2 PC2-6400
EVGA 8800 ACS3 KO GTX with EK waterblock
Auzentech X-Fi Prelude
2x500Gb Seagate Barracuda SATA2
Dual loop with Thermochill Pa120.2 and 120.3
  #52 (permalink)
Old June 24, 2007, 10:17 AM
lowfat's Avatar
Level up: 60% Level up: 60% Level up: 60%
Level: 14 - 237 points to level up
Is that stock CPU and GPU? Seems a little low to me, but i don't think I've ever ran stock.
essentials: Intel E8400 - eVGA 780i - Galaxy 8800GT SLI - 4GB Patriot Viper PC2-8500
storage: (3) WD6400AAKS - Dell Perc5/i RAID5
case & power: Tagan Black Pearl [under construction] - Gigabyte Odin GT - Silverstone CMD01-ESA
cooling: DTEK Fuzion - (2) Swiftech MCW60 - Swiftech MCP355 w/ EK X-150 - Koolance Compression Fittings - Feser One Tubing
  #53 (permalink)
Old August 13, 2007, 04:06 PM
Default Well over 12000
I got 12359 with an overclock of 3.5Ghz and a slight overclock on my video card to 600/1030. I am attaching a screen shot. By the way, this is a stable overclock...
INTEL Conroe E6700
EVGA NVIDIA 680i Rev A1
OCZ 2GB DDR2 PC2-6400 Platinum Revision 2
EVGA GEFORCE 8800GTX
2 x Western Digital Raptor 150GB
ThermalTake TOUGHPOWER 750W (Modular)
Silverstone TJ09 Black w/ window
Thermalright 120 Ultra Extreme
OCZ XTC Memory Airflow Cooler
Logitech G15
Logitech MX518
Asus 18x SATA w/ Lightscribe
2 x Dell FPW2407 Rev A04
  #54 (permalink)
Old September 3, 2007, 12:33 PM
r0k0's Avatar
Level up: 34% Level up: 34% Level up: 34%
Level: 12 - 270 points to level up
stock mine did 10 088
getting a new PSU Soon.. and TT Watercooling setup... yeah i know its cheap.. but hey.. its gonna do a better job cooling my cpu at stock speed than my stock intel cooler..! :P
Core 2 Quad Q6600 G0 2.4Ghz | Asus Striker Extreme |4 x 1GB Corsair Dominator DHX PC2-1066Mhz | eVGA 8800GTX 768MB | Coolermaster Staker 830 Black | OCZ EvoStream 720W | Seagates 'Cuda 400GB SATA2 | Win XP Pro SP2 | Logitech G-51 | Samsung 206BW 20.1"
  #55 (permalink)
Old September 3, 2007, 04:42 PM
Level up: 90% Level up: 90% Level up: 90%
Level: 14 - 62 points to level up
Nooooo...don't go TT water cooling lol. Get one of the pre configured kits from ncix....I believe they are around $150-$170. just my two cents but I'm sure one of the experts Miso or Patriote will agree.(I think lol) Far better set up for the money.
http://www.ncix.com/products/index.p...nufacture=NCIX
Amd FX60 @2.9
Asus A8R32-MVP Deluxe
2 Gig Corsair XMS 4000PT
2 Ati X1900's @XTX Speeds
2 WD 160gg HD's in Raid 0
XFi Platinum
Tt 680 Watt PSU
SATA Plextor DVD
(Liquid Cooled) Swiftech Apex Ultra and 2 MCW 60's
Kandalf
  #56 (permalink)
Old September 3, 2007, 04:50 PM
ya i think he's looking at ease of setup and maintenance free. i've done the water cooling thing back when there was no "self contained" kits. But if i had to do it again i'd opt for one over a "assembly required" kit. If it leaks or breaks it's their **** up not mine.
3800X2@2.2GHz--2gb PC3200--200Gb Maxtor SATA2--eVga 8800GTS 320mb--eVga nForce4 SLI mobo--Klipsch 4.1--Antec nine hundred case w/Vantec 120mm on side--Vista Premium 64bit
Join our Folding@Home team!
  #57 (permalink)
Old September 3, 2007, 05:55 PM
Amon's Avatar
I can't run 3Dmark06, but I scored something like 2300 in 3DMark05.
**Defunct** Socket 939 San Diego 4000+::2GB PC3200::Radeon 9600 SE 128MB::200GB HDD::24" Dell 2407WFP-HC::WinXP x64/x86 dual boot
Dell Vostro 1500 laptop::Socket P Merom T7100::2GB PC5400::Go 8600m GT 256MB::660GB HDD::15.4" WXGA+, 24" Dell 2407WFP-HC::WinXP
  #58 (permalink)
Old September 10, 2007, 10:00 AM
Maybe the original poster can collect all these numbers and put them up on the first page :)
INTEL Conroe E6700
Logitech G15
Logitech MX518
  #59 (permalink)
Old September 10, 2007, 11:19 AM
^ Seconded....
I'm downloading it now to see what my lame x1900aiw can do before I throw a couple o/c'd x2900xt's into the box in a months time.
Edit, yep the x1900aiw is a major bottleneck right now
\/ Currently out of commision
Asus P5W DH Deluxe pencil modded
Intel QX6700es @3425mhz (12x285) 1.38v
Modded Coolit Freezone 120mm 115cfm fan
Team Xtreem DDR2 800 @950mhz 4GB
Koolance 1200w self contained water cooled psu
2x XtremePC OC'd x2900xt's 780/2200
Samsung 305T 2560x1600
Samsung 204b 1600x1200 (x2)
Sapphire Theater Pro 650
  #60 (permalink)
Old September 12, 2007, 03:44 PM
Level up: 56% Level up: 56% Level up: 56%
Level: 12 - 178 points to level up
this is the best I can do... sometimes if I run it Ill get a higher number, but Ill stick with this one since its the most frequent..... No overclock on the GPU's... just the CPU.
E6600 Dual Core @3.4GHZ (1511 FSB) / 2x 8800 GTX KO ACS3 PCI-E 630MHZ 768MB 2.0GHZ SLI'd / Raptor 74GB / Antec 1200 Hundred Gaming Case / Corsair XMS2 TWIN2X2048-6400C4 2GB 2X1GB PC6400 DDR2-800 CL 4-4-4-12
680I SLI LGA775 MOBO / Samsung DVD+RW / Enermax Galaxy 1000 wats PSU / 24" Samsung CinkMaster
Cooling:
Swiftech Dual rad
Swiftech Single rad
Swiftech Micro Res
Swiftech Apogee GT Cpu block
2x Koolance 8800 GTX Full Coverage Water blocks
Feser One Blue Fluid
Forum Jump
Search this Thread:
Advanced Search
Hotfix for 3DMark06/05/03 and PCMark05 Eldonko Drivers 0 February 29, 2008 01:12 PM
Performance Review nVidia in 3DMark06 Prof. Dr. Silver Video Cards 2 November 18, 2007 11:11 AM
AquaMark 3 Benchmark Prof. Dr. Silver Overclocking, Tweaking and Benchmarking 2 November 15, 2007 08:26 PM
New 3Dmark06 World Record by Shimano SKYMTL Reviews & Articles from the Web 5 July 25, 2007 04:40 AM
