Register Sweepstakes VB Image Host Members List LAN Calendar Search Today's Posts Mark Forums Read
LinkBack Thread Tools Search this Thread Display Modes
  #31 (permalink)
Old June 4, 2007, 12:28 PM
Delavan's Avatar
DurkaDurka,
If you give you GFX card a little more on the core speed (650),I'm sure you'll reach 11000...whether you'll try it or not is completely up to you, but just t olet you know. Also, make sure the GPU fan spins at 100% (you prolly already did that anyway, just checkin..)
E6420@3.2Ghz/ Gigabyte P965-DS3 Rev.3.3 F10 Bios/2 Gigs Mushkin EM-PC6400/Arctic Cooling Freezer 7/GeForce 8800 GTS 640Mb SC 651Mhz-2020Mhz/Antec TP3 650W/Thermaltake Armor Jr./Seagate 160G/WD 250G/Audigy 2ZS/Logitech Z-2200
3DMarks06 (12223 pts)
  #32 (permalink)
Old June 4, 2007, 06:25 PM
Level up: 42% Level up: 42% Level up: 42%
Level: 11 - 197 points to level up
I'm probably going to give 3dmark06 another go this week, breaking 11k would be sweet. I have Riva Tuner set to run the fan @100% 24/7 since the bastards at nvidia thought they would remove the option from the driver.
I am only running the stock cpu heatsink at the moment, going to pick up something better soon. Hopefully that will allow the 6400 to hit 3.4'ish stable. Right now I max out at about 3.2 before I get blue screens.
Q6600@3.2ghz
Asus P5N32-E Sli
4gb OCZ Platinum DDR2 @855hmz 4-4-4-12 2T
Antec P180
Galaxy 8800GT. 700/2000/1800
Corsair HX-620
Thermaltake Power Express 250W
Raptor150, WD 500gb. WD 300GB
X-Fi Extreme Music
  #33 (permalink)
Old June 4, 2007, 07:42 PM
lowfat's Avatar
Level up: 97% Level up: 97% Level up: 97%
Level: 14 - 23 points to level up
Delavan, do you have any compare links? I'd like to see how mine compares to yours.
My new one is in my sig.....11115
essentials: Intel E8400 - eVGA 780i - Galaxy 8800GT SLI - 4GB Patriot Viper PC2-8500
storage: (3) WD6400AAKS - Dell Perc5/i RAID5
case & power: Tagan Black Pearl [under construction] - Gigabyte Odin GT - Silverstone CMD01-ESA
cooling: DTEK Fuzion - (2) Swiftech MCW60 - Swiftech MCP355 w/ EK X-150 - Koolance Compression Fittings - Feser One Tubing
  #34 (permalink)
Old June 5, 2007, 08:34 AM
Delavan's Avatar
Well, not sure I know what you mean...is it a screenshot (with all the temps/clocks...)? If it is I'll try..not really knowledgeable about how to do it though. I tried to capture a screenshot with Microsoft paint and it doesn't work...with ultimate paint it might.
  #35 (permalink)
Old June 5, 2007, 09:25 AM
Scratch's Avatar
Level up: 74% Level up: 74% Level up: 74%
Level: 13 - 127 points to level up
control/printscreem
Paint/edit/paste
EVGA 680i, Q6700 @ 3.3Ghz 1.3v, 3x WD 160GB , 2x2GB Mushkin Redline pc8000 @ 1000mhz CL5-5-5-15 2t
1x EVGA 8800GTS 640MB @ 651/1525/1003mhz, Silverstone Zeuss 750w PSU,
CoolIt MTec Freezone Elite CPU Cooler, SilverStone Tj09 case, Dell 2407WFP Monitor
  #36 (permalink)
Old June 5, 2007, 12:10 PM
sswilson's Avatar
Super Moderator
In your 3DMark `06 project manager you can select a "publish" box, this will give you a "compare" link at the top of your project screen.
Gigabyte P35-DQ6 / E8400 / 4X 1 Gig Crucial Balistix PC2 8500 / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S /
MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / Swiftech Apogee GT WB / Samsung 931BF
DFI P965-S Dark / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 /
Creative Audigy2 / NEXUS NHP-2200 / Swiftech H20-220 / Highspeed PC Tech Station / BENQ FP91G+
  #37 (permalink)
Old June 5, 2007, 12:44 PM
Delavan's Avatar
Thanks for the replies, I'll post tonight.
  #38 (permalink)
Old June 5, 2007, 01:58 PM
lowfat's Avatar
Yes , this is what i was referring to. To see where your system compares with mine. I want to see if the extra 320mb of video memory helps in certain areas or not.
  #39 (permalink)
Old June 5, 2007, 03:29 PM
Delavan's Avatar
Sorry for the lack of experience in benchmarking...I got my rig last week after all! And my last comp had no AGP/PCI lock setting in bios, so no good OCs...
Futuremark - ORB - Result Analyzer
Anyway I"ll scr*w it up...It says Rank 29 compared to similar systems.
  #40 (permalink)
Old June 5, 2007, 03:34 PM
Delavan's Avatar
next
Forum Jump
Search this Thread:
Advanced Search
Hotfix for 3DMark06/05/03 and PCMark05 Eldonko Drivers 0 February 29, 2008 01:12 PM
Performance Review nVidia in 3DMark06 Prof. Dr. Silver Video Cards 2 November 18, 2007 11:11 AM
AquaMark 3 Benchmark Prof. Dr. Silver Overclocking, Tweaking and Benchmarking 2 November 15, 2007 08:26 PM
New 3Dmark06 World Record by Shimano SKYMTL Reviews & Articles from the Web 5 July 25, 2007 04:40 AM
