Register Sweepstakes VB Image Host Members List LAN Calendar Search Today's Posts Mark Forums Read
LinkBack Thread Tools Search this Thread Display Modes
  #21 (permalink)
Old May 26, 2007, 05:55 PM
lowfat's Avatar
Level up: 45% Level up: 45% Level up: 45%
Level: 15 - 358 points to level up
my latest
10286 3DMarks
Futuremark - ORB - Project Comparison
CPU @ 3GHz. VGA @ 600/950.
  #22 (permalink)
Old June 2, 2007, 06:53 AM
Delavan's Avatar
10118 3DMarks 06 I didn't OCed the graphics card yet.
Would I notice a significant improvement over my actual "out-of-the-box" speeds?
E6420@3.2Ghz/ Gigabyte P965-DS3 Rev.3.3 F10 Bios/2 Gigs Mushkin EM-PC6400/Arctic Cooling Freezer 7/GeForce 8800 GTS 640Mb SC 651Mhz-2020Mhz/Antec TP3 650W/Thermaltake Armor Jr./Seagate 160G/WD 250G/Audigy 2ZS/Logitech Z-2200
3DMarks06 (12223 pts)
  #23 (permalink)
Old June 2, 2007, 04:19 PM
Babrbarossa's Avatar
Super Moderator
Was that done at 3.2 GHz? That's pretty darned good! You should be able to get that GPU up to about 660 and 1000 which might put you over the 11K mark.
Gaming Rig: evga 680i rev. A1 // Q6600 @ 3.51 // evga 260GTX 216SC// 2X2GB GSkill DDR2 1000// Antec TP Quattro 850w // CM Stacker 830
Water Cooling: D-Tech Custom Fuzion // Danger Den 680i chipset block // Swiftech Stealth// HW Labs Black Ice GTX Xtreme 360 // Swiftech mcp655 pump
HTPC: Asus Commando // e6400 @ 3.4 // Crucial Ballistix PC2 8000 // evga 260GTX 216SC// LG super opti-blue HD optical drive// DVB clone PCI satellite receiver//OCZ GXStream 700w // ACFP7 CPU cooler // Antec p180
  #24 (permalink)
Old June 2, 2007, 06:32 PM
Delavan's Avatar
Yes I got that score at 3.2Ghz...
I guess I should try to OC my GTS 640! I'm a little hesitant though! I mean, I seen that quite a few people got problems over 630 (core). Rivatuner my best bet? I'll probably reach 11000 or close to it, but will I notice any "visible" benefits? I mean I run my fave games all maxed out on a regular 19" CRT, not like I'm running a 24" or bigger LCD.
Edit: I'll give Ntune a shot...It's running a stability test right now... I clocked at 630 core and 950 memory (conservative, but a start!).
  #25 (permalink)
Old June 2, 2007, 07:16 PM
Super Moderator
No, I would say not- it would just be for bragging rights- mine is water cooled and I don't leave mine any higher than 610 for 24/7 operation- I don't think it would hurt me to go higher as my temps are below 40, but there's not much point.
  #26 (permalink)
Old June 3, 2007, 10:21 AM
Scratch's Avatar
Level up: 13% Level up: 13% Level up: 13%
Level: 14 - 507 points to level up
woohoo broke 10k with the new NVidea drivers
EVGA 680i, Q6700 @ 3.3Ghz 1.3v, 3x WD 160GB , 2x2GB Mushkin Redline pc8000 @ 1000mhz CL5-5-5-15 2t
1x EVGA 8800GTS 640MB @ 651/1525/1003mhz, Silverstone Zeuss 750w PSU,
CoolIt MTec Freezone Elite CPU Cooler, SilverStone Tj09 case, Dell 2407WFP Monitor
  #27 (permalink)
Old June 3, 2007, 11:39 AM
sswilson's Avatar
Super Moderator
5645 with my new 1950pro @ 620/749
Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S /
MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW
DFI P965-S Dark / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 /
HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF
  #28 (permalink)
Old June 3, 2007, 02:57 PM
Delavan's Avatar
I got my 8800GTS 640 clocked at 630 core and 950 memory using RivaTuner.
It's kinda too easy, although the self test didn't let me go to 1000 for memory. I'll run a 3Dmarks06 tonight, my new comp is not hooked up to the internet yet. I'm moving to an other province in a few days and I didn't bother to set everything up, I didn't take the router out of the package yet.
I'll just do a quick swap to hook it up, run the benchie and take a screenshot. I realize that running my games with graphics at stock or OCed doesn't really matter, I can't see the difference (well I can hear it...the fan at 100%)...LOL
Maybe with Crysis and Quake wars, I'll see a difference, but I'll be running them games on DX 9c...
  #29 (permalink)
Old June 3, 2007, 05:02 PM
Delavan's Avatar
Ok this is my last result. (EVGA 8800 GTS 640Mb)
I reached 11032 in 3DMarks06! I'm trying to take a shot, but doesn<t work.
Anyway, I set the GPU core clock to 648
Shaders 1512
Memory 945
Rivatuner gives me a warning when I crank the memory above 950...I'll try again
(you know the "test" button).
Anyway, without the friendliness and technical support from you folks, I wouldn't be there getting an "above 11000" 3Dmarks06...makes you wonder what hardware the guy who scored 24000 had "under the hood"...
Thanks guys!
  #30 (permalink)
Old June 4, 2007, 07:31 AM
Level up: 42% Level up: 42% Level up: 42%
Level: 11 - 197 points to level up
I scored 10450 with my e6400@3.1, 8800gts @ 630/1800 using XP pro. The highest I have been able to hit with Vista is 10322.
Forum Jump
Search this Thread:
Advanced Search
Hotfix for 3DMark06/05/03 and PCMark05 Eldonko Drivers 0 February 29, 2008 01:12 PM
Performance Review nVidia in 3DMark06 Prof. Dr. Silver Video Cards 2 November 18, 2007 11:11 AM
AquaMark 3 Benchmark Prof. Dr. Silver Overclocking, Tweaking and Benchmarking 2 November 15, 2007 08:26 PM
New 3Dmark06 World Record by Shimano SKYMTL Reviews & Articles from the Web 5 July 25, 2007 04:40 AM
