  #281 (permalink)
Old September 26, 2008, 07:34 PM
rjbarker's Avatar
Level up: 27% Level up: 27% Level up: 27%
Level: 13 - 358 points to level up
@MPG, its that OC on that GTX280 that is insane...I'm impressed!!!...almost 180 GB/sec Bandwidth...thought I was doing good at 158..hahaha
Wolfdale E8400 4.05 GHz vCore 1.45v "Unlinked"
Evga Nforce 780i A2
Evga 2 x GTX 280 SSC SLI - OC 720 Mhz / 2.52 Ghz
Mushkin XP Redlines 4GB (2 x 2GB) PC 8000@ 1000 MHz 5-5-5-12 2T-2.05v
Raptor 74 GB
Seagate Barracuda 320 GB
LG DVD RW Dual Layer Lightscribe
Asus 16X DVD ROM
Corsair HX 1 kW - Modular
Silverstone Temjin TJ 09 B/W - Exhaust: 3 x 120mm, Intake: 2x 120mm - Scythe S Flex
Zalman 9700 LED
Samsung Syncmaster 2443 BW - 24"
XP SP3
3DMark 06 - 20,276
  #282 (permalink)
Old September 26, 2008, 10:58 PM
rjbarker's Avatar
Able to get just a tad more out of her..
I'm pretty sure thats it...I really believe the GPU is maxed, however, it almost seems that with these GTX2xx series Cards they need to stretch their wings a little and then ..boom...a previous OC that didn't work (stable), is now stable..very odd. This is my 2nd GTX 2xx Series Cards to play with in last week.
For all its worth!
Cheers
Evga Nforce 780i A2
Raptor 74 GB
Asus 16X DVD ROM
Zalman 9700 LED
XP SP3
3DMark 06 - 20,276
  #283 (permalink)
Old October 5, 2008, 04:17 PM
Alwaysrun's Avatar
Level: 9 - 172 points to level up
Just Got my system up and running haven't OC'd anything yet, everything in my sig is stock except the Palit Radeon HD 4850 which I let ATI Overdrive have it's way with.
Stock the card runs 625/993 at ambient temp of 24C with case wide open temps are 32C idle / 41C load (2 hours of crysis everything on High 4xAA).
With this card OC'd idle is 37C and 47C load (again 2hrs of Crysis).
Guess I can still push it more but for some reason when I crank ATI overdrive up to it's max it passes but then 3dmark 06 freezes up and says "IDirect3DDevice9::Presentfailed:devicelost(D3 DERR _DEVICELOST)" Strange as I can play Crysis just fine with ATI overdrive set to 675/1050 which is the max the sliders go. Other than this small prob the card seems very cool and I expect to reach somewhere around 15K 3dm06 score once I tweak my HD and OC the E8400.
CoolerMaster CM 690 - Asus P5Q-E - Intel E8400 Wolfdale 3.0 GHz @3.85 1.26v - Corsair TX 750Watt - OCZ Vendetta 2 *Lapped - 2x2 GB Corsair Dominator PC2-8500
Palit Radeon HD 4850 @ 670/1023 - Seagate Barracuda 7200.11 640 GB - Maxtor 250GB - Samsung Lightscribe DVD+RW SH-223Q - 22" Samsung SyncMaster 2253BW
  #284 (permalink)
Old October 19, 2008, 09:11 PM
CTA's Avatar
CTA CTA is offline
Level up: 41% Level up: 41% Level up: 41%
Level: 13 - 289 points to level up
with new 3.2ghz OCed and i am very impressive... jump from 12k something...
old: no brand silver case, 3g365p-ve, p4 2.6GHz HT, ga-8sq800 ultra, 1024 gb of generic ram (:oops:), MSI ti4200 8x 128mb, 520gb of HDD ( two maxtor and one seagate) and other
NEW: cm 690, hx620, intel q9450, True Black, p5q deluxe, 2gbx2 ram of mushkin xp pc2 8500, evga 9800gx2. wd caviar se 16 640gb, 4x zm-f3 fans.
  #285 (permalink)
Old November 9, 2008, 10:38 PM
North of You's Avatar
Level up: 40% Level up: 40% Level up: 40%
Level: 1 - 23 points to level up
I NEED H2O!!!
  #286 (permalink)
Old November 9, 2008, 11:05 PM
cwestwell's Avatar
Level up: 60% Level up: 60% Level up: 60%
Level: 12 - 165 points to level up
Originally Posted by North of You View Post
I NEED H2O!!!
I can hardly see your info in your pick but...correct me if I am wrong do I see a Q6600 at 3.6Ghz and a 8800 getting you a Score of 18K+ I may not be reading that right but it looks damn impressive...wow if you are able to run your Q6600 at 3.6 on Air that is a triumph and a half you got yourself a good chip there I would definetly put that under water for some kickass OC.
Another unrelated question just how north are you.
_______________________________________________
E8600 420x10 |Thermalright 120 Black | Maximus Formula | ATI 4870X2 | 4GB Buffalo FireStiX PC8500 | Corsair HX1000 | Lian Li V2010B | Vista Ultimate 64bit
3D Mark 06 - 20079
Q6600 334x9 |Thermaltake Blu Orb | ASUS P5Q-PRO| ATI 2900XT | 6GB Corsair XMS2 PC6400 | Corsair HX520 | Lian Li V600B | Vista Home Premium 64bit
3d Mark 06 - 12775
  #287 (permalink)
Old November 9, 2008, 11:07 PM
cwestwell's Avatar
I see RJ is now getting a better Score then me with his SLI GTX280's guess I will need to hit the OC a bit more to try and top my current score.
3D Mark 06 - 20079
3d Mark 06 - 12775
  #288 (permalink)
Old November 10, 2008, 12:01 AM
rjbarker's Avatar
Are those 4870x2 capable of being CrossFired? Along with your E8600 @ 4.6 Ghz....now your talking :)
Evga Nforce 780i A2
Raptor 74 GB
Asus 16X DVD ROM
Zalman 9700 LED
XP SP3
3DMark 06 - 20,276
  #289 (permalink)
Old November 10, 2008, 12:31 AM
rjbarker's Avatar
Default Next...a 4.2 Ghz Run Perhaps...? Damn "CO" Stepping !!
Pretty much Max, without pumping 1.55v to my Core to get 4.275Ghz run...
Satisfied though..
Evga Nforce 780i A2
Raptor 74 GB
Asus 16X DVD ROM
Zalman 9700 LED
XP SP3
3DMark 06 - 20,276
  #290 (permalink)
Old November 10, 2008, 07:20 AM
cwestwell's Avatar
My Biggest hold back is the X2 wont go over 767 / 942 with it's Air cooling even with the fans maxed. I was Planning to get another X2 only I haven't seen them for anything nearly as cheap as I got it in September...So after Xmas New GPU New Cooling.
3D Mark 06 - 20079
3d Mark 06 - 12775
Hotfix for 3DMark06/05/03 and PCMark05 Eldonko Drivers 0 February 29, 2008 02:12 PM
Performance Review nVidia in 3DMark06 Prof. Dr. Silver Video Cards 2 November 18, 2007 12:11 PM
AquaMark 3 Benchmark Prof. Dr. Silver Overclocking, Tweaking and Benchmarking 2 November 15, 2007 09:26 PM
New 3Dmark06 World Record by Shimano SKYMTL Reviews & Articles from the Web 5 July 25, 2007 05:40 AM
