  #211 (permalink)
Old March 30, 2008, 06:05 PM
Level up: 10% Level up: 10% Level up: 10%
Level: 11 - 305 points to level up
Default Getting Better
Well I can am getting better scores and still have lots to play with.
Yipeeee..... Next goal 16000
CasheKicker
RIG #1 - AMD64 3500+ // Asus A8N-E // Radeon x1950xt // 2g Ram (4x512) // Basic Budget Case // Enermax Liberty SLI 500W Modular PSU // WD Caviar 250g
RIG #2 - Intel E8400 // TRU-X 120 w noctua NF-P12 // Gigabyte GA-X38-DQ6 // nVidea 8800GTS 512 OC // 4g Ram Crucial Ballistic PC8500 1066Mhz (4x1g) // Antec 900 Gamers Case // OCZ 850w Gamer XTream PSU // WD Raptor 150g // Samsung 226BW & 17"KDS CRT/ Logitec G-15
  #212 (permalink)
Old March 30, 2008, 06:36 PM
yycraven's Avatar
Level up: 29% Level up: 29% Level up: 29%
Level: 13 - 344 points to level up
Nice score Cashekicker , hope to see those score once I get a E3110.
nice video card speeds
My rig
Intel Quad core X3210 OC@ 3.4GHz ,Coolmaster Hyper 212 , Asus P5Q-E, G skill F2-8500CL5D 4GBPK, eVGA 9800GTX KO 512MB, WD 750GB HDD 16MB cache sata II, CM 690 with 6 120mm fans, Corsair HX620-watt power supply, Pioneer DVR-112, OS Vista Ultimate 32bit
Second Rig for FOLDING.
Intel E2140 OC @ 2.4GHz, Asus P5K, G.Skill PC6400 2GB, BFG 8800 GT OC 512MB, Maxtor 40Gig HDD, Thermaltake 550W PSU, XP Pro
heatware
  #213 (permalink)
Old March 30, 2008, 07:18 PM
Yeah I am happy with the 8800gts for sure. I have the fan set @ 50% with these settings and I am staying below 60deg C.
Very Cool. I dont think I have any more clockling left in her though at least not at stock voltages. I am not that familiar with Riva Tuner yet and only know how to use the low level settings. So you never know, I may be able to do better when I learn more.
Also I think I have found my CPU limit unless I start playing with voltages. I will post my Bios in my OC thread when I get a chance. Perhaps someone that knows more about OCing can give me a few pointers.
Currently Running 3915.2 Mhz with 9x435 giving me a rated FSB of 1740.1 at stock 1.23v and my Ram is 522.0 (1044mhz), 5:6, 5,5,5,12 2T @ 2.0v
CasheKicker
  #214 (permalink)
Old April 3, 2008, 01:19 AM
rjbarker's Avatar
Level up: 27% Level up: 27% Level up: 27%
Level: 13 - 358 points to level up
Cool
Not sure if it works just tossing the Link in here...
ORB - Please login
Wolfdale E8400 4.05 GHz vCore 1.45v "Unlinked"
Evga Nforce 780i A2
Evga 2 x GTX 280 SSC SLI - OC 720 Mhz / 2.52 Ghz
Mushkin XP Redlines 4GB (2 x 2GB) PC 8000@ 1000 MHz 5-5-5-12 2T-2.05v
Raptor 74 GB
Seagate Barracuda 320 GB
LG DVD RW Dual Layer Lightscribe
Asus 16X DVD ROM
Corsair HX 1 kW - Modular
Silverstone Temjin TJ 09 B/W - Exhaust: 3 x 120mm, Intake: 2x 120mm - Scythe S Flex
Zalman 9700 LED
Samsung Syncmaster 2443 BW - 24"
XP SP3
3DMark 06 - 20,276
  #215 (permalink)
Old April 3, 2008, 03:03 PM
yycraven's Avatar
this is the best I can do, I have hit my max I think with my card. Until I change the stock cooling. Have the fan running at 100%, and temps are 65C so not bad.
I'm happy with the score.
My rig
heatware
  #216 (permalink)
Old April 3, 2008, 04:42 PM
r0k0's Avatar
i ran everything stock after i installed my Q6600 and i got 12 302 i'll have to get a Screebiw tho..
Core 2 Quad Q6600 G0 2.4Ghz | Asus Striker Extreme |4 x 1GB Corsair Dominator DHX PC2-1066Mhz | eVGA 8800GTX 768MB | Coolermaster Staker 830 Black | OCZ EvoStream 720W | Seagates 'Cuda 400GB SATA2 | Win XP Pro SP2 | Logitech G-51 | Samsung 206BW 20.1"
  #217 (permalink)
Old April 3, 2008, 08:16 PM
rjbarker's Avatar
Just curious, when you say "at Stock 1.23v" and not having adjusted Voltages in the same sentence......have you manually adjusted your vCore to 1.23 or is your vCore still set at "Auto"???
1.23v seems pretty astoundng for 3.9Ghz...
Just curious as I'm also new to OC'ing and was originally simply changing my FSB Speed to achieve OC's and leaving Voltages on "Auto", I was promptly advised that this is not the way to do it, as your System will pump all kinds of Voltage to your CPU given the higher FSB.....so....been playing around with trying to tweak the most optimal vCore with the set FSB...
Cheers
Evga Nforce 780i A2
Raptor 74 GB
Asus 16X DVD ROM
Zalman 9700 LED
XP SP3
3DMark 06 - 20,276
  #218 (permalink)
Old April 12, 2008, 10:44 AM
Default 16086 single gt
Well I tried to hit 16*** and managed 16086 with a single 8800gt with the core @ 746 linked. Everything is on air and I dont want to hurt my little baby (QX9650). Probably can squeeze a bit more, when I get my ram back from OCZ and push the CPU and GPU a bit more but in reality probably not much more with this card.
ORB - Compare
  #219 (permalink)
Old April 21, 2008, 07:12 PM
sswilson's Avatar
Super Moderator
Initial run with my new Gigabyte 8800GTS (birthday present... :) ).
ORB - Compare
15271 without any OC on the vid card. These come stock @ 700/1674/999.
Damn.... gotta learn how to OC a Nvidia card now...... :)
Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW
ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF
  #220 (permalink)
Old April 21, 2008, 08:33 PM
magictorch's Avatar
Level up: 9% Level up: 9% Level up: 9%
Level: 18 - 804 points to level up
Happy birthday SSwilson..and what a fine birthday present! are you watercooling it?
E6750/ Xeon 3350
DFI X38 LT
2 x 4870
74gb Raptor for OS, games
Thermalrock Dragon Case (sprayed black).
Loop 1: MCR 220 int. ; Apogee GT block.
Loop 2: MCR 320; Swiftech Res.;
2x EK FC blocks.
Pumps: 2x MCP655.
Hotfix for 3DMark06/05/03 and PCMark05 Eldonko Drivers 0 February 29, 2008 02:12 PM
Performance Review nVidia in 3DMark06 Prof. Dr. Silver Video Cards 2 November 18, 2007 12:11 PM
AquaMark 3 Benchmark Prof. Dr. Silver Overclocking, Tweaking and Benchmarking 2 November 15, 2007 09:26 PM
New 3Dmark06 World Record by Shimano SKYMTL Reviews & Articles from the Web 5 July 25, 2007 05:40 AM
