![]() Really happy to crack 15,000 mark. New forceware 174.74 saw it increase around 800pts. Asus Striker Extreme Intel Q6600 OC @ 3.0 Scythe Ninja (thinking about swapping to Ultra 120) OCZ Gold @ 800 4-3-4-8 2T Galaxy 8800GT @ 650/950 in SLI Seagate 7200.11 500GB (second one on it's way for RAID 0) PC Power & Cooling Silencer 610w Hiper Anubis case Samsung 226BW LCD |
| Geez must be nice. The new 174.74's dropped my score by nearly 2000 points! I think I'll go back to the 169's till they get these sorted out.
__________________ Q6600 @ 3.6GHz w/ D-Tek Fusion Gigabyte GA-P35-DS3R rev.1 2x 2GB PC8000 Mushkin Redlines @ 1000MHz w/5-5-5-12 timings Asus EN8800GT Top stock speed w/ DD Maze5 OCZ Gamer Xtreme 600W PSU Cooler Master Cosmos on water |
I haven't heard anything about the new 174.74 drivers, but TweakForce's modded 169.61 drivers are really good. 169.61 was originally for workstation cards, but apparently gives a bit of a boost. I'll try out the 174.74 drivers though and see how it goes.
__________________ QX9650 @ ... | Asus P5Q-E |2x2GB Dominator @ ... VisionTek 4870 @ 825MHz/4.6Ghz|WD 640GB Black PCP&C 750W Silencer | HT Omega Claro X3350 @ 4187MHz |
Here is my 1st attempt at overclocking benchies. Not bad but I know my CPU still has a lot of room left in it. I have not adjusted any voltages yet, apart from bringing my RAM up from the Gigabyte default of 1.8v up to 2.0v, the crucial spec is 2.2v so I am still under spec there. I do not have a registered ver. of 3dmark, it would be nice to see my broken down scores. I am still using the forceware 169.21, I see others are using different Betas, does it make a big difference? Are there any risks to using Betas?
__________________ CasheKicker RIG #1 - AMD64 3500+ // Asus A8N-E // Radeon x1950xt // 2g Ram (4x512) // Basic Budget Case // Enermax Liberty SLI 500W Modular PSU // WD Caviar 250g RIG #2 - Intel E8400 // TRU-X 120 w noctua NF-P12 // Gigabyte GA-X38-DQ6 // nVidea 8800GTS 512 OC // 4g Ram Crucial Ballistic PC8500 1066Mhz (4x1g) // Antec 900 Gamers Case // OCZ 850w Gamer XTream PSU // WD Raptor 150g // Samsung 226BW & 17"KDS CRT/ Logitec G-15 Last edited by CasheKicker; March 30, 2008 at 07:50 AM. |
Nice clocks on the GPU!! Is that load temps for the cpu? I think I read something about the backplate on your board giving you grief with the heat-sink backplate.
__________________ E6750/ Xeon 3350 DFI X38 LT 2 x 4870 74gb Raptor for OS, games Thermalrock Dragon Case (sprayed black). Loop 1: MCR 220 int. ; Apogee GT block. Loop 2: MCR 320; Swiftech Res.; 2x EK FC blocks. Pumps: 2x MCP655. |
I removed the Crazy Cool backplate to install the TRU-X, the load temps according to CoreTemp and HWMonitor are about 56-51 idle 43/43, where in Real Temp they are 10deg lower.46-41. idle 33/33. Not sure which ones to trust but I still feel the idel temps seem to be a bit high, although much lower than they were with the intel stock cooler on. My ambient room temp is a steady 20deg. My idle temps on my AMD64 3500+ are about 28 with the stock cooler so it has me wondering if they are high or not.
__________________ CasheKicker RIG #1 - AMD64 3500+ // Asus A8N-E // Radeon x1950xt // 2g Ram (4x512) // Basic Budget Case // Enermax Liberty SLI 500W Modular PSU // WD Caviar 250g RIG #2 - Intel E8400 // TRU-X 120 w noctua NF-P12 // Gigabyte GA-X38-DQ6 // nVidea 8800GTS 512 OC // 4g Ram Crucial Ballistic PC8500 1066Mhz (4x1g) // Antec 900 Gamers Case // OCZ 850w Gamer XTream PSU // WD Raptor 150g // Samsung 226BW & 17"KDS CRT/ Logitec G-15 |
Might just be a software irregularity. Or more remotely some sort of cpu internal voltage setting that hasnt been made clear in the bios-(random guess). The difference between load and idle is good, and the temps are well within safe limits. Doesn't look like a seating issue. The TRU-X likes fans with high static pressure though.
From reading the reviews here and on other sites, it appears I am using one of the best fans on the market for the TRU-X 120mm, The Noctua NF-P12.
sorry didnt read your sig. in enough detail. yea thats a great fan!! absolutely love them-apart from the color. .put one on my GTX, and two on the radiator. So looks more like software then?? Anyway youll be at 4ghz in no time
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Hotfix for 3DMark06/05/03 and PCMark05 | Eldonko | Drivers | 0 | February 29, 2008 02:12 PM |
| Performance Review nVidia in 3DMark06 | Prof. Dr. Silver | Video Cards | 2 | November 18, 2007 12:11 PM |
| AquaMark 3 Benchmark | Prof. Dr. Silver | Overclocking, Tweaking and Benchmarking | 2 | November 15, 2007 09:26 PM |
| New 3Dmark06 World Record by Shimano | SKYMTL | Reviews & Articles from the Web | 5 | July 25, 2007 05:40 AM |
