I scored 14899 with my new galaxy 8800GT, clocks at 725/2000/1850 Rest of the equipment is in my sig I'm going to try and push it past 15k tonight ;) ORB - Compare
__________________ Q6600@3.2ghz Asus P5N32-E Sli 4gb OCZ Platinum DDR2 @855hmz 4-4-4-12 2T Antec P180 Galaxy 8800GT. 700/2000/1800 Corsair HX-620 Thermaltake Power Express 250W Raptor150, WD 500gb. WD 300GB X-Fi Extreme Music |
this is my best score yet. ![]() video card speed 725/1618/1025
__________________ Intel Quad core X3210 OC@ 3.4GHz ,Coolmaster Hyper 212 , Asus P5Q-E, G skill F2-8500CL5D 4GBPK, eVGA 9800GTX KO 512MB, WD 750GB HDD 16MB cache sata II, CM 690 with 6 120mm fans, Corsair HX620-watt power supply, Pioneer DVR-112, OS Vista Ultimate 32bit Second Rig for FOLDING. Intel E2140 OC @ 2.4GHz, Asus P5K, G.Skill PC6400 2GB, BFG 8800 GT OC 512MB, Maxtor 40Gig HDD, Thermaltake 550W PSU, XP Pro heatware |
I've got a Q6600 OC'd @ 3150mhz, 4g pc6400 corsair Twinx RAM, XFX Geforce 8800GTxxx AD 512,on a XFX 680i MOBO I'm gettin 14300 with these settings I OC'd the GPU and got 14769 those are the best STABLE numbers I have gotten so far any tips for goin higher but also stayin stable? I can post the proof if you guys need it. I get 11948 on stock settings.
Broke 15k woohoo 15163 up'd the voltage a little and it became quite a bit more stable, bumped up the GPU timings from 670/975 to 700/1000 and had the CPU 3431mhz hoping with a few more little adjustments i can get at least 15500 maybe 16k
My best score with a q6600 b3 stepping @ 2.8 and an 8800gt is 12444. Not too bad, it does everything I need it too, but if I could only crack 13000, then maybe 13500, then maybe... Last edited by Mecher; March 9, 2008 at 06:06 PM. |
Well i just bought my second XFX Geforce 8800 GT xxx Alpha Dog Edition GPU and have installed in with the SLI bridge that came with my XFX 680i LT MOBO, also just looked into it and I do have the Q6600 G0 SLACR which was a pleasant suprize as i ordered an OEM version of Tigerdirect.ca. I have my CPU OC'd at 3.1Ghz(need a bigger power supply only a 500w)and both the GPU's with the lastest drivers and SLI mode enabled I get 15500 in 3dmark06 running on Vista Home Premium. I think I should be getting higher numbers with and SLI system at least over 16000. I know I need to buy a bigger power supply, but with this increase my proformance enough or is there something else I should be doing. Any helpful tips would be great guys |
| Quote:
I have them SLI enabled and when I run 3dmark06 in XP I get 17400ish I will go set the 3d settings to proformance instead of quality but I have it set the same in XP and am getting numbers I like a lot better(I have proof of the numbers in XP and Vista also) I ordered a Antec NeoPower 650 should be here within the week. in vista I get a driver failure nvdblah somethin or other then it recovers. don't seem to have any problems other than not having directx 10 in XP
| Quote:
__________________ Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Hotfix for 3DMark06/05/03 and PCMark05 | Eldonko | Drivers | 0 | February 29, 2008 02:12 PM |
| Performance Review nVidia in 3DMark06 | Prof. Dr. Silver | Video Cards | 2 | November 18, 2007 12:11 PM |
| AquaMark 3 Benchmark | Prof. Dr. Silver | Overclocking, Tweaking and Benchmarking | 2 | November 15, 2007 09:26 PM |
| New 3Dmark06 World Record by Shimano | SKYMTL | Reviews & Articles from the Web | 5 | July 25, 2007 05:40 AM |
