  #151 (permalink)
Old February 14, 2008, 08:14 AM
Level up: 25% Level up: 25% Level up: 25%
Level: 7 - 104 points to level up
I gotta say I love this e4500, I put the vcore up to 1.375 and got another 200mhz out of it, and my idle temps didn't go up a degree.
if My fan on my arctic 7 spins slow, ( like 900 rpm ) it goes up 1 degree. I know there is a video of someone runnning this processor without a heatsink on Youtbue, but I didnt think it'd be like this.
I'm trying to hit 3.5
But I've got sooooooo many tweaking options in my bios I go crazy. When reviewers have no idea what half your bios settings do, it tends to get confusing.
Just for a test though I dropped my PCI-E bandwith to 8x. my 3dmark score didnt change a bit.
OMG PCI-E 2.0.... we dont even use all of Pci-e 1.0 yet.
  #152 (permalink)
yycraven's Avatar
Level up: 29% Level up: 29% Level up: 29%
Level: 13 - 344 points to level up
Originally Posted by Cptn Vortex View Post
Here is my little run I did with the Celeron Dualcore. 1.6GHZ stock, got it to 3.1GHZ, still trying to get that 100% OC! 11222 3DMarks, with the dual 8800GTX's. I think this Cele is bottlenecking the cards...
I think your right, the cele must be bottlenecking the cards, cause you should have gotten a higher score then that, I would think.
My rig
Intel Quad core X3210 OC@ 3.4GHz ,Coolmaster Hyper 212 , Asus P5Q-E, G skill F2-8500CL5D 4GBPK, eVGA 9800GTX KO 512MB, WD 750GB HDD 16MB cache sata II, CM 690 with 6 120mm fans, Corsair HX620-watt power supply, Pioneer DVR-112, OS Vista Ultimate 32bit
Second Rig for FOLDING.
Intel E2140 OC @ 2.4GHz, Asus P5K, G.Skill PC6400 2GB, BFG 8800 GT OC 512MB, Maxtor 40Gig HDD, Thermaltake 550W PSU, XP Pro
heatware
  #153 (permalink)
Old February 14, 2008, 11:09 AM
a35599's Avatar
I hit a wall on my Q6600 at 2.95, @ 1313 FSB. If I push pass that, crash.Name:  1313fsbjpg.jpg
Asus Striker Etreme II
QX9650 @ 3.85ghz
2 X BFG 9800GX2
XFI Fatality SB
4GB OCZ 3P1600EB4GK
Zalman 9700LED
2 X 150GB Raptors
4 X 500GB WD
Thermaltake 1200W PSU
XP/Vista Dual Boot
  #154 (permalink)
Old February 14, 2008, 11:24 AM
3.0charlie's Avatar
What do you mean it crashes? My 1st Quad runs at 3.2 GHz (400MHz FSB), while my second one runs at 3.7 Ghz (463MHz FSB).
Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182
HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B
  #155 (permalink)
Old February 14, 2008, 11:48 AM
Cptn Vortex's Avatar
Level up: 42% Level up: 42% Level up: 42%
Level: 21 - 701 points to level up
Yeah with my quad at 2.8GHZ, and the 2 cards SLI I pull over 16000. I recently took one card out, and put it in a machine I have which is a Maximus Formula SE, Q6600 @ 3.6GHZ 4GB RAM and 2x500GB RAID0, and scored slightly over 14000.
The Vortex H20
Case....not sure what to call it
DFI X38 LT
Xeon X3210 @ 3.2GHZ 1.30V
PNY 9800GX2 (750/2200)
4GB Corsair Dominator 2x2gb kit DDR2 1066 5-5-5-15 2.0V
Ultra X3 1000W PSU
HT Omega Striker
2x500GB Hitachi RAID 0, 250 Seagate
Sharp 32" Aquos 1080p
Benq W500 1080i Pojector.
Watercooling:
Loop 1 - D-Tek Fuzion Quad Nozzle Bowed, MCR320+Zalman ZM-F3 Fans, MCP655, MCRES Micro.
Loop 2 - DB-1, DD 9800GX2 block, MCW30, MCR320, tLine res.
  #156 (permalink)
Old February 15, 2008, 03:35 AM
r0k0's Avatar
with me clocked at 3.0Ghz.. i did 11115
stock clocks on the GPU
Core 2 Quad Q6600 G0 2.4Ghz | Asus Striker Extreme |4 x 1GB Corsair Dominator DHX PC2-1066Mhz | eVGA 8800GTX 768MB | Coolermaster Staker 830 Black | OCZ EvoStream 720W | Seagates 'Cuda 400GB SATA2 | Win XP Pro SP2 | Logitech G-51 | Samsung 206BW 20.1"
  #157 (permalink)
Old February 15, 2008, 10:10 AM
Wow, I'm starting to feel better.
I guess my Budget build isn't fairing so bad in comparison.
I'd just like to know why do some peoples sm2.0/3.0 seem to be similar, where me and say YY have 2000 point spread.
If I enable Xfire ( obviously put another card in ) my Sm2.0 goes up by 400 points, my 3.0 goes up 2200?? Seems really really odd.
CPU: E4500@3.3ghz ( 300X11@1.430v) MB: DFI LanParty ICFX3200 T2R/G
RAM: OCZ Platinum XTC rev2 ( 4-4-4-15 2t ) GPU: BFG 9800GTX
COOLING: Swiftech 120 Compact - Swiftech - MCW30 SOUND: HT omega Striker 7.1
CASE: NZXT Lexa Blackline PSU : OCZ Gamestream 700w
  #158 (permalink)
Old February 15, 2008, 07:43 PM
zlojack's Avatar
Level up: 1% Level up: 1% Level up: 1%
Level: 16 - 711 points to level up
Wow... I just popped in my 3870x2 and
MM H2GO ~ GA-X58-UD5 ~ i7 920
4GB OCZ Gold Edition DDR3-1600GHz ~
~ Soundblaster Fatal1ty XtremeGamer Pro ~ Samsung SyncMaster 245b 24"
2 WD Raptor 150 GB (RAID0)/ WD Caviar 500 GB ~ Samsung DVD/RW ~ Vista Ultimate 64
  #159 (permalink)
Old February 15, 2008, 11:56 PM
Here's mine:Q6600 3.56ghz formula maximus 0903 2gigs crucial 8500 2 3870's
  #160 (permalink)
Old February 19, 2008, 04:23 PM
belgolas's Avatar
Level up: 79% Level up: 79% Level up: 79%
Level: 17 - 168 points to level up
well I got 10840 with stock GPU and overclocked Q6600 @ 3.42 GHZ. If I overclock my GPU I can get close to 12000 points.
Intel Core 2 Quad Q9550 @ 3.6, Asus Formula Maximus X38, 2 x 4 gigs of DDR2 1000 mhz, 1 TB sata HD, 18x DVD burner, Visiontek 4870 X2, Sound Blaster X-Fi extreme music, G15 and G5 keyboard and Mouse, crappy 5.1 speakers, Dell 24" 2407WFP, Enermax Galaxy 1000w. Lots of cooling. Cooler Master Cosmos 1000.
http://www.cybernations.net
A Nation Simulation Game
Hotfix for 3DMark06/05/03 and PCMark05 Eldonko Drivers 0 February 29, 2008 02:12 PM
Performance Review nVidia in 3DMark06 Prof. Dr. Silver Video Cards 2 November 18, 2007 12:11 PM
AquaMark 3 Benchmark Prof. Dr. Silver Overclocking, Tweaking and Benchmarking 2 November 15, 2007 09:26 PM
New 3Dmark06 World Record by Shimano SKYMTL Reviews & Articles from the Web 5 July 25, 2007 05:40 AM
