  #141 (permalink)
Old February 13, 2008, 11:52 PM
Prof. Dr. Silver's Avatar
Hardware Canucks Reviewer
Originally Posted by yycraven View Post
I downloaded the free version, got it about 2 days ago. when you run your 3d06 do you have the deep freeze test on yours on yours.
Yes I do....Are you sure you're 3DM06 version is the latest one? I think it should be V1.10...
It should be 4 screen test and two CPU tests.
  #142 (permalink)
Old February 13, 2008, 11:54 PM
yycraven's Avatar
Level up: 29% Level up: 29% Level up: 29%
Level: 13 - 344 points to level up
I only have the basic edition, thats why I do not see the score in the background. will have to get pro, or advance.
My rig
Intel Quad core X3210 OC@ 3.4GHz ,Coolmaster Hyper 212 , Asus P5Q-E, G skill F2-8500CL5D 4GBPK, eVGA 9800GTX KO 512MB, WD 750GB HDD 16MB cache sata II, CM 690 with 6 120mm fans, Corsair HX620-watt power supply, Pioneer DVR-112, OS Vista Ultimate 32bit
Second Rig for FOLDING.
Intel E2140 OC @ 2.4GHz, Asus P5K, G.Skill PC6400 2GB, BFG 8800 GT OC 512MB, Maxtor 40Gig HDD, Thermaltake 550W PSU, XP Pro
heatware
  #143 (permalink)
Old February 14, 2008, 01:15 AM
yycraven's Avatar
here is my new benchmark score
wondering if my cpu Volts is to low 1.296V
My rig
heatware
  #144 (permalink)
Old February 14, 2008, 01:22 AM
BALISTX's Avatar
Level up: 54% Level up: 54% Level up: 54%
Level: 21 - 564 points to level up
Nice score.
If your system is stable then your vcore is fine. I had mine at stock at 1.20 when I OCed my E2180 to 2.75GHz.
  #145 (permalink)
Old February 14, 2008, 01:27 AM
yycraven's Avatar
So far it is stable, been running at this setting's all day. Played a game for 1hr and benched for a few hrs..lol
but did not noticed the volts till now.
orthos is running(50mins so far) and will see how that go's.
My rig
heatware
  #146 (permalink)
Old February 14, 2008, 01:32 AM
BALISTX's Avatar
Are you running core temp to keep an eye on your temps? I found with Orthos my temps didn't change after the first hour of stress testing. I was hitting around 54C for both cores. I was also running Intel TAT as well and it was at 53C for both cores. Here is the link to that. Pureoverclock: Hardware reviews and news for overclockers!
  #147 (permalink)
Old February 14, 2008, 01:38 AM
yycraven's Avatar
thanks for the tip, downloading it now. been using my thermo meter to check heat. and if your wondering what that is ES Infrared Thermometer - EST-65
mine is calibrated, cause of my job I do.
My rig
heatware
  #148 (permalink)
Old February 14, 2008, 01:43 AM
BALISTX's Avatar
That's a pretty nice piece of hardware and a nice price too. On sale for $45.00
  #149 (permalink)
Old February 14, 2008, 01:53 AM
yycraven's Avatar
yeah, Its US$ but you can get it for same price in CAD as well. Just open case up and point laser to your NB and gives you a reading, and it you turn off laser, gives you reading of inside case. Give or take 1C.
my TAT will not work , do you know why
My rig
heatware
  #150 (permalink)
Old February 14, 2008, 02:01 AM
BALISTX's Avatar
I may just have to pick one of those up. I'm not sure why TAT isn't working for you.
WOOT my 1000th post.
Hotfix for 3DMark06/05/03 and PCMark05 Eldonko Drivers 0 February 29, 2008 02:12 PM
Performance Review nVidia in 3DMark06 Prof. Dr. Silver Video Cards 2 November 18, 2007 12:11 PM
AquaMark 3 Benchmark Prof. Dr. Silver Overclocking, Tweaking and Benchmarking 2 November 15, 2007 09:26 PM
New 3Dmark06 World Record by Shimano SKYMTL Reviews & Articles from the Web 5 July 25, 2007 05:40 AM
