  #121 (permalink)
Old January 28, 2008, 05:49 PM
Level up: 8% Level up: 8% Level up: 8%
Level: 14 - 540 points to level up
Dang, 15 k with a single gts? i'd say if thats true then the g92 IS alot better. It was all i could do to get 14k out of this one, even with stable temps.
vista 64 on these rigs
Q9450 @ 3.5Ghz | E8400 @ 4.2Ghz
8gb Muskin Redline. | 2gb Kingston Hyperx
________________________________|_________________ ______________
EVGA 780i FTW ----\--||___||--/---- EVGA 780i SLI
Antec TP Quatro 1000W \ :==^==: / Antec TP Quatro 850W.
Nvidia 9800 GX2 X 2 SLI \|--o--|/ Nvidia 8800 GTS X 2 SLI
1X 500GB Western Digital. \_____/ 3X 150GB WD RAPTOR RAID-0
  #122 (permalink)
Old January 28, 2008, 05:50 PM
bobletman's Avatar
Level up: 78% Level up: 78% Level up: 78%
Level: 8 - 40 points to level up
I had to OC my gts to get 15k, the card crashes before it overheats when you are overclocking it so heat is never a problem.
Q6600 Core 2 quad @ 3.0Ghz
2gb of patriot ram reduced latency.
500GB 7200 rpm Seagate (baracuda)
BFG nvidia 8800 GTS 512 MB G92 core
Zalman CNPS9700 LED CPU fan
Ultra X-Blaster computer case
P5K-E Wifi edition MOBO
G15 keyboard and G7 mouse
22 inch widescreen samsung
Z5300e speaker system
3Dmark06 score 15K
  #123 (permalink)
Old January 28, 2008, 05:52 PM
what were your speeds when you were overclocking the gts?
  #124 (permalink)
Old January 28, 2008, 05:56 PM
bobletman's Avatar
I actually cant remember, I think I might be trying to break my OC record soon so i will tell you then and I will post pics.
3Dmark06 score 15K
  #125 (permalink)
Old January 28, 2008, 06:04 PM
right on dude, i'm looking forward to it. the settings at 14k on my gts was 743/1715/104 max temp was 36°C and your right, it still failed before it overheated, but i was still able to get alot more clock out of it after i cooled it, so its definatly worth cooling.
  #126 (permalink)
Old January 31, 2008, 07:20 PM
sswilson's Avatar
Super Moderator
First night with the new Vid card and I have to say I'm impressed all to hell!!!!
Doubt I can pull much else out of the card, and I really doubt that even pumping the CPU up to 4G is gonna get me that elusive 15K.
Pretty damn happy with this stock cooler. Pumped it up to 100% for this run, but 70% is more in line with still being quiet.
No 860 BIOS block on the new HIS boards. Had this one running at 975, but couldn't complete `06. Mem seems happiest around 1300, but I didn't see any artifacts at the 1330 from this run (usually can see black spots in snow of the last benchmark when it starts to go).
Overall, pretty damn happy!!! :)
Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW
ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF
  #127 (permalink)
Old January 31, 2008, 07:35 PM
3.0charlie's Avatar
Great card, isn't? Runs like a charm, hardly gets hot. And with that number, I'll have to tweak my own Quad and push the 8800GT a little bit more... have you tried going for a 8x multi, instead of a 9x? You'd need 475FSB, and the faster clock may help you reach 15000... here's my last run, with the Quad at 3.6, 450FSB.
Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182
HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B
  #128 (permalink)
Old January 31, 2008, 07:42 PM
sswilson's Avatar
Super Moderator
I'm pretty sure I can get a `06 4G out of this chip at X9 but it's gonna take a fair bit of cpu VID to keep it stable. In previous testing I didn't see any benefit to running it @ 8X, but I'll have to give it another go. (just gotta get those mem timings down right.... :) ).
I'll probably make a run sometime in the next month after I find my happy place with all the new gear finally together, and a fresh install of XP.
I haven't done any gaming yet so it remains to be seen what affect the new cpu will have on case temps, but I suspect they'll be slightly better with the heat from the card being vented outside of the case.... :)
  #129 (permalink)
Old February 1, 2008, 12:22 AM
1Tanker's Avatar
Level up: 27% Level up: 27% Level up: 27%
Level: 13 - 357 points to level up
Well, i haven't seen any 3850 results here yet... so, although much lower than the average here, not bad for a $200 card(sorry,i didn't grab a screenshot).
10,866
- E6600-3519
- GA-P35-DS3L
- Diamond Viper HD3850(512MB)-729/1854
- 2x1GB Corsair PC2 6400C4...391/4-4-4-6
- Seagate 7200.10 Sata3g 320GB
- XP-Pro
Futuremark - ORB - Project Comparison
  #130 (permalink)
Old February 1, 2008, 01:43 AM
Prof. Dr. Silver's Avatar
Hardware Canucks Reviewer
LOL...I believe I outdid myself again, new motherboard, new RAM, same OC on CPU and GPU! Result: 12974 3DMark06 points!
Screenshot:
Just like you said sswilson, that elusive 13K is what I want to reach! Oh and this run was done on XP Pro...the last on I did was on Vista....I scored 12588 or so?
Hotfix for 3DMark06/05/03 and PCMark05 Eldonko Drivers 0 February 29, 2008 02:12 PM
Performance Review nVidia in 3DMark06 Prof. Dr. Silver Video Cards 2 November 18, 2007 12:11 PM
AquaMark 3 Benchmark Prof. Dr. Silver Overclocking, Tweaking and Benchmarking 2 November 15, 2007 09:26 PM
New 3Dmark06 World Record by Shimano SKYMTL Reviews & Articles from the Web 5 July 25, 2007 05:40 AM
