Old January 13, 2009, 09:00 AM
Default whats better when ocing?
bumping up the multiplier and keeping fsb low?
or bumping up the fsb and keeping multiplier low?
CPU:Intel i5 6600k - Corsair H110
GPU:EVGA GTX980Ti FTW Edition
HDD:250GB Samsung Evo 850 SSD, 3TB WD Black
MOBO:Asus Z-170 Deluxe
RAM:G.Skill Ripjaws V F4 2800mhz 16GB
PSU:Silverstone 950W
CASE:Silvertstone TJ07
Keyboard:Logitech G15 V2
Mouse:Razer DeathAdder
Case Cooling:2x92mm exhaust,2x120mm exhaust, 2x120mm Ultra Kaze(3000RPM)intake.
Running:Win7 64-bit Ultimate
Old January 13, 2009, 09:10 AM
sswilson's Avatar
I seem to get better memory intensive benchmark results from the highest FSB my hardware will support so my vote is "lower multi + higher FSB".
Old January 13, 2009, 09:23 AM
Mark's Avatar
The only benefit of running at a high FSB with a lower multiplier is in synthetic benchmarks but running your Ram strapped at 400 with tighter timing, seems to echo in relevance.
Give it a try and let us know:)
CHEERS
Old January 13, 2009, 04:37 PM
okay so theoretically...3800\6 =633.33 * 4 = 2536 "fsb"
so i did 634 *6 = 3.8ghz around.
Old January 13, 2009, 04:45 PM
wt lol i tried that, bumped up vcore to 1.3v just to be safe and will lower later, and somehow it jumped itself to 4.09ghz?
and cpu multiplier was 9 which doesn't make sense? cause 634* 9 = like...5ghz
wtf???
Old January 13, 2009, 04:49 PM
is cpuz messing with me? -_- keeps giving me diff things....could this be because of intel's speedstepp?
Old January 13, 2009, 05:03 PM
sswilson's Avatar
Yes, speedstep needs to be disabled for accurate overclocking. (C1 + EIST? ).
What board/cpu are you using? 600+ FSB is pretty far out there..... :)
Old January 13, 2009, 06:20 PM
asus striker II formula. E8400 C2D c0 stepping. and just in case, using ocz reaper hpc 8500 1066mhz 4gb ram
Old January 13, 2009, 06:31 PM
okay changed fsb to 507.x7.5 @1.2vcore
successful boot, turned off intel speedstep, opened realtemps, my temps are great.
but in cpu-z, core voltage reads 1.104V-1.088V (changes), and core speed changes from 3041.2@ x 6 to 3801.6@ x7.5 ....so it switches..good?bad?
Old January 13, 2009, 06:38 PM
btw, my ram sets is supposed to be pc2-8500 but cpu-z reading 6400...??? how do i change that?
Whats my best option trayton Video Cards 5 December 27, 2008 11:22 PM
whats the cheapst MB and cpu Shadowmeph CPU's and Motherboards 10 May 22, 2008 06:27 AM
Whats after x86? Speculation is welcome. Mysteryous CPU's and Motherboards 5 December 29, 2007 07:29 AM
whats this mean ? Jim CPU's and Motherboards 8 July 25, 2007 05:39 AM
Whats your opinion on this? ragenrok RAM 11 April 25, 2007 04:30 AM
