<~----> Something wrong with this picture (Using Real Temp 2.70) - Hardware Canucks
Old January 8, 2009, 04:04 PM
Default Something wrong with this picture (Using Real Temp 2.70)
It's the first time using Real Temp and I downloaded the latest version.
The overclocking setting passed 7hours of Prime 95 x64 test on Vista Ultimate x64.
I ran Real Temp(used run as administrator) during the test and the picture was taken after the test.
See anything suspicious with the pictures?
About the sensor movements? The sensor movements differ almost everytime. For example, once I got 3,3,5,5 another time I got 18,14,12,12.
And what areTJ Max XS bench? For XS bench, I get about 1510 all the time. Eleet and Real Temp show slightly different temperatures. I use 8-8-8-24-74 2T (2:8) memory timing.
Thanks.
Real Temp or Core Temp ?? FrankyG Overclocking, Tweaking and Benchmarking 11 September 29, 2008 11:24 PM
Q about real temp by intel and CPUID monitor contractk Overclocking, Tweaking and Benchmarking 8 March 29, 2008 09:51 AM
GPU temp is 55 degrees on H20 - something I did wrong? JayDee Water Cooling 5 August 2, 2007 01:33 PM
CPU temp or Core temp? E6420 NOOB Delavan CPU's and Motherboards 18 May 28, 2007 05:07 AM
TAT is not showing the real temp! Why? francois methot Overclocking, Tweaking and Benchmarking 5 March 12, 2007 09:32 AM
