Old January 6, 2009, 09:12 PM
EaGle1337's Avatar
Default ram timing help.
I have no clue how to optimize my ram.
it's at 5-5-5-15 and that's all i've done/know.
Old January 6, 2009, 09:26 PM
get everest and play around.
different timings and fsb:ram ratios.
Old January 6, 2009, 09:34 PM
EaGle1337's Avatar
what would everest do?
Old January 6, 2009, 09:36 PM
give you a memory benchmark.
Old January 6, 2009, 11:33 PM
Jackquelegs's Avatar
It's better to know the consequences of RAM overclocking first. Do not overvolt the RAM too much or let it overheat.
Go on the manufacturer's forums, there should be recommended timings. However if you want to push timings lower, you will have to do so manually, usually by 1 value at a time.
If that is all you know, you should not worry too much about it, as you probably won't notice any difference unless benchmarking.
Iapetos
Zephyranthes
Old January 6, 2009, 11:47 PM
EaGle1337's Avatar
I know of the consquences. The problem is there isn't timings that i can find for these g.skills. I won't be goign out of the spec'd voltages.
Old January 7, 2009, 12:36 AM
Let them run stock.
Its all they need.
DRAM Timing TheRock New Builds 7 November 25, 2008 12:46 PM
Mushkin HP2-6400 & P5N-E Timing Advice ipaine RAM 6 September 30, 2008 06:00 PM
