  #31 (permalink)
Old August 10, 2009, 09:20 PM
howpet's Avatar
Originally Posted by enaberif View Post
Its also not the most reliable.
Its been known to fail on stock clocks ;)
Just my 2 cents to input, but anyone atempting linpak with stock clocks probably atempting same with stock cooling = fail.
Myself if it successfully passes 5 times and temps are good using max memory why stress with prime for 8-10 hrs just to realize same results.
  #32 (permalink)
Old August 10, 2009, 10:05 PM
shayan288's Avatar
Originally Posted by rjbarker View Post
If all your going to run is P95 be sure to run both Small FFT and Blend (for Memory)...LinX is probably hitting instability with your Memory which small FFT didn't detect.
Acutally.. I bumped up the vcore by one notch and i am now officially 24 hours prime 95 stable and I am also IntelBurnTest stable. (I ran the 10 stacks or whatever you call em) So yeah, I believe I am stable "enough"
The 288
Q9550 E0 stepping @ 4Ghz
Gigabyte EP45 UD3P
G.Skill pc2 8500 1066mhz RAM
Western Digital 250gb
Antec 1200
XFX HD5970
Steelseries Xai Laser Mouse
Windows 7 Ultimate x64
S&M Stress Test Program Gav Overclocking, Tweaking and Benchmarking 11 July 6, 2012 01:21 PM
Prime95 and other stress tests Dwayne Overclocking, Tweaking and Benchmarking 22 September 7, 2008 07:05 PM
What's a good GPU stress program? biff Video Cards 10 March 29, 2008 06:39 AM
Prime 95 Error RogerzRig Overclocking, Tweaking and Benchmarking 52 February 20, 2008 10:03 PM
4Ghz Q6600 Prime stable turtletrax CPU's and Motherboards 14 August 13, 2007 10:05 AM
