Old January 2, 2009, 12:45 AM
BrianHanna's Avatar
Default Can i push this further on air than it already is?
i keep hearing that the e8400 should never go above 73 or something along those lines.
Most post which i read people say that there e8400 runs at 40 or so at idle, but mine runs at 22/21 on idle and hits 42/39 on load.
Do i have a magical e8400 or are my temps just wrong?
in the case that they are right (which i have no reason to believe otherwise), do you think i should try to push it further?
if so, any opinions as to how far i should be able to push it?
Old January 2, 2009, 12:49 AM
Depends on your ambient temps.
Old January 2, 2009, 12:50 AM
BrianHanna's Avatar
wish i had a thermometer >.<
Old January 2, 2009, 06:03 AM
BrianHanna's Avatar
got it to 4.3
seems stable so far.
Old January 2, 2009, 06:06 AM
sswilson's Avatar
I'm a bit surprised that the Zalman is working as well as it is, but see no reason to question your temps at the voltage you've got set.
Looks like you got a great chip!!! Congrats! :)
Old January 2, 2009, 06:17 AM
BrianHanna's Avatar
i cant seem to get it to 4.5, i dont wanna try my luck too hard though, i increased vcore twice to try get it to run at 500 fsb, but it wouldnt go.
i figure it might have to do with my RAM
but i have pc2-8500 ram, which means it should be able to handle a cpu fsb of at most 533 right?
other than that, what would be preventing it from even booting at a fsb at 500?
im happy with what it is at now, and dont want to kill it for 200more Mhz but im just curious to see what would be causing the prob.
Old January 2, 2009, 06:33 AM
sswilson's Avatar
Not very motherboard / CPU combination will do 500 FSB, and even those that do sometimes take a fair bit of tweaking to get them there. As far as the ram goes.... my experience is that it's the 1:1 which causes the problems more often than not. I've had several boards that wouldn't do high(er) FSB 1:1 even though the memory had no problems running at that speed with a different ratio.
You can try bumping the northbridge volts up a bit to see if that helps, but don't beat yourself up too much. That's a great OC you've got going already with the kind of voltage you're using.
And yeah.... usually that last 200Mhz takes a disproportionate amount of voltage. Once you get up to those kinds of OCs you start to hit a wall and your Vcore vrs clockspeed ratio is no longer linear.
Old January 2, 2009, 06:54 AM
BrianHanna's Avatar
And yeah.... usually that last 200Mhz takes a disportionate amount of voltage. Once you get up to those kinds of OCs you start to hit a wall and your Vcore vrs clockspeed ratio is no longer linear.
to tell the truth im quite happy with whats it's at now, and if there is any sign of problems, i'd be just fine lowering it back to 4ghz, as there is no real need for more than that anyways.
Asus p6x58d-e / i7 930 @ 4ghz / G.skill 1600mhz 2x3gb 9-9-9-24 / Corsair TX750 / XFX HD 6850 1GB x2 @ 870/1070/ Coolermaster HAF 932 / Noctua nh12-up / Western Digital 500g Caviar black /Western Digital 1TB Caviar black 60Gb/ Seagate 7200.11 500g / OCZ Vertex 3 SSD / Samsung 2253BW / G5 / MX518 /
Old January 2, 2009, 11:46 AM
punk_zappa's Avatar
Looking at your other post, are you trying to OC with all 4 Gb or RAM? Try with just 1 stick as OC'ing all 4 doesn't give max results. And follow wilson's suggestion of raising NB and FSB voltage.
Old January 3, 2009, 07:46 PM
I have 8500 oc at 4009 mhz fsb 422. 1.3 (little under that at load cpuz) but if i try stock value of nb/sb/ram (everything 0,1v up) i get hard reset under orthos within 1 hour. So, some mbo just ask for litle more juice. Afther that i hit 24h full load w/o problem. Also i get 51 max with ninja 2 1000 rpm.
I didnt bother with lowering voltage to optimal (cpu) because i plan to go higher...
Anyway, do you guys get a error on oc in prime/orthos, or hard reset (no freeze, just black screen and pre bios boot) usualy if cpu need more juice?
How do you like my new rad? Push-Pull FTW!!! Sniper Water Cooling 26 December 8, 2008 09:09 AM
LGA775 Push Pins (OCZ Vendetta II) Mr. Gruntsworthy Air Cooling 11 October 11, 2008 09:56 PM
Fans for Push/Pull on PA120.2 Supergrover Water Cooling 20 September 14, 2008 07:18 PM
Push vs Pull on a Rad? Supergrover Water Cooling 10 October 16, 2007 07:13 PM
Help Me Push My X2 3800+ SKYMTL Overclocking, Tweaking and Benchmarking 7 March 28, 2007 04:51 PM
