Old June 7, 2007, 08:55 PM
sswilson's Avatar
Super Moderator
Nice to see a (1t) there on the mem. Not all S775 boards have that ability.
Are you interested in playing a bit to see if you can get more bandwidth out of your memory?
Most reports suggest that running memory @ 1-1 (533) offers the best bandwidth with the c2ds.
If your board will support FSB of 450, a cpu multi of 7 would give you a slightly higher cpu freq (3150), but the benefits of running the mem @ 1-1 are supposedly significant.
Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW
ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF
Old June 7, 2007, 09:13 PM
JayDee
Guest
Posts: n/a
Always fun to try :)
I've been reading that my RAM will behave strangely with different voltages (it's rated for 1.4 volts). I'll try to push the RAM and see if 1:1 gives a hit.
Old June 9, 2007, 05:11 AM
JayDee
Guest
Posts: n/a
Starting to gain a little more confidence with the OC - fun :)
Haven't been able to get the RAM running at 1066 yet.
11,000 3DMarks on the horizon though :)
My vid card seems to want to OC quite abit more but the temps scare me. Are temps over 70 degrees wise for a 8800GTS?
Old June 15, 2007, 08:09 PM
hey Jay,
What are you using to keep your CPU cool?
Old June 15, 2007, 10:02 PM
JayDee
Guest
Posts: n/a
I'm using a Scythe Ninja Rev B and the fan that came with it with AS Ceramique for TIM. I've liked it's cooling ability but the huge size of thing is a pain as it covers my RAM slot #1. I also hate the "clip on" system it uses for the fan as I could not setup the fan to run in "pull" mode as the fan blades would contact the heatsink fins and thus I was forced to use a "push" setup and that covers RAM slot 1.
Old August 12, 2007, 09:47 PM
JayDee
Guest
Posts: n/a
Well I installed H20 a couple weeks ago and just got around to overclocking today.
My rig now:
Armor case
Corsair 620 PSU
Asus P5N32-E Plus 650i
E6600 @ 3.6ghz
Crucial Ballistix Tracer PC6400 4x1gb (1:1 @ 4-4-4-12)
8800GTS 320mb @ 660/927
H20 setup:
Swiftech MCP655-B 12V Industrial Water Cooling Pump
D-TEK Customs Fuzion CPU Water Block
D-TEK Customs Fuzion GFX GPU Water Block / Swiftech MC14 Bga Memory Heatsinks / Swiftech MOSFET sinks
Black Ice Xtreme II Rad (2x120mm) with 4 x120mm Logisys 63CFM fans in push + pull on a rheobus
Swiftech 7/16" tubing and Tygon 1/2" tubing
Tygon 1/2 inch tubing
Swiftech MCRES-MICRO Clear HI-FLOW Water Cooling Reservoir
Old August 12, 2007, 11:57 PM
Level up: 13% Level up: 13% Level up: 13%
Level: 17 - 692 points to level up
Push that 8800GTS some more.
I got mine at 675/1030 on stock air. I'm sure you can get near it or better.
Can you get CoreTemp and then post your idle/load temperatures?
Xeon Quad X3350 | 3.40GHz (Damn X38 chipset)
ASUS Maximus Formula | BIOS RF0410
2GB Corsair Dominator | 850MHz
4-4-4-12-2T
2GB OCZ Platinum Rev2 | 850MHz 4-4-4-12-2T
HIS ICEQ4 Turbo HD4850 @ 700/1200
X-Fi XtremeMusic
Antec TruePower Quattro 850W
Antec 900
[ HEATWARE ]
Old August 13, 2007, 07:00 PM
JayDee
Guest
Posts: n/a
Here it is.
I'm not familiar with Coretemp but my ambiant is about 23 degrees and the idle temp is lower than ambiant?
Don't know how that can be...
