Old December 23, 2008, 06:26 PM
Default q9300 ocing
I have a P5Q-E mobo with q9300 4x1 OCZ DDR2 800, have it running at 3Ghz bus at 400, temps are fine but should I up the voltage on the cpu and memory?
Current readings:
CPU voltage at 1.296c, memory at 1.8c.
CPU temp at 22c, memory at 32c.
Old December 23, 2008, 06:45 PM
How long will Orthos/Prime95 run before failing? If it goes for 8 hours, you do not need to up any voltages.
Old December 23, 2008, 06:54 PM
I just started playing with the settings, havent tested it yet.
Just thought I needed to up the voltage on ram or cpu, I would like to reach 3.3Ghz but it wont load with bus at 450.
Old December 23, 2008, 07:48 PM
SugarJ's Avatar
If you're in a hurry, put your CPU at 1.40v and your memory at 2.0-2.1V. Then see how high you can get your bus speed.
Personally, I'd take the time to creep up on it, bumping vCore one notch at a time, raising bus speed until it fails, bump and repeat. But put your mem at 2.0V anyway, you'll need that to overclock that ram probably.
Old December 23, 2008, 08:04 PM
3.0charlie's Avatar
Just make sure you don't reach 65c-70C.
Hydro-Quebec is salivating...
Old December 23, 2008, 09:11 PM
Reached 3.3Ghz, CPU at 1.32V 19c, ram is at 2.2V 420 bus 36c.
Just played some l4d seems to be all stable, I dont know if should even bother going higher.
I was reading that my ram will go upto 2.2V so I thought to give it a shot.
While running Orhtos for 45 min my temps were: CPU 45c Mem 37c
I got some fans for my ram, I think it was a good investment.
Old December 24, 2008, 12:07 AM
Got it to 3.6Ghz, wasnt stable and crashed, backed it to 3.3Ghz.
Quad Core Q9300 PC 8800GT 3GB RAM, 750GB HD, Antec designer rom0n Buy/Sell & Trade 6 June 26, 2008 10:58 AM
[M] Q9300 Overclocked to 3.8Ghz with Subzero Cooling! Hardware Canucks CPU's and Motherboards 0 May 2, 2008 10:11 AM
E3110 now or Q9300 later rom0n CPU's and Motherboards 5 April 28, 2008 10:10 AM
Q9300 Oc rom0n CPU's and Motherboards 1 April 27, 2008 08:24 PM
Q9300 review by X-bit labs yycraven Reviews & Articles from the Web 6 March 24, 2008 08:39 AM
